你好,
我需要一些威廉希尔官方网站 帮助编程/阅读一个M95F118AS。 我有一个Mb95F118AS,它有已知的吹针,所以我试着从它上面读取程序代码,把它放在一个新的空白芯片上。 我已经从HTTP://www. CyPr.com文件/软件和DealVals/Flash -MCU程序员1下载了“Flash MCU程序员程序F2MC-8FX”,但是程序只有一个M95F118B/M目标微控制器。我看不懂芯片。 在不设置MOD引脚浮动的情况下,我正在从处理器获得数据,所以处理器是活的,并且连接到它的4MHz晶体正在工作。 通过将MOD引脚设置为高,处理器处于编程状态(我猜)——但是当我点击软件上的下载时,它不会响应。 我还设置P12/KK到高和P13至低的编程指南。 请问我使用的软件是否正确?或者如果我做错了什么? 谢谢您, 加布里埃尔青年 26905830191015985017910744194924911o.jPG 80 K 269097 901 10156985 14923 575 4 42626728 41IO JPG 84.4 K 连接故障 41.3 K DSC02680.JPG 324.3 K 以上来自于百度翻译 以下为原文 Hi, I need some technical help with programming/reading a MB95F118AS. I have a MB95F118AS Which has known blown pins so I am trying to read the program code off of it to put onto a new blank chip I have. I have downloaded the “FLASH MCU Programmer for F2MC-8FX” From http://www.cypress.com/documentation/software-and-drivers/flash-mcu-programmer-1 but the program only have a MB95F118B/M target Microcontroller. I am unable to read the chip. Without setting the MOD pin floating, I am getting data from the processor so the processor is alive and the 4MHz Crystal connected to it is working. With setting the MOD pin to HIGH the processor sits in the programming state (I guess) – But when I click download on the software it does not respond. I have also set P12/UCK to High and P13 to LOW as per the programming guide. Can you please advise if the software I am using is correct? Or if there is something I'm doing wrong? Thank You, Gabriel Young
1。在“设置环境”中选择了正确的COM端口吗?
2。编程模式相关引脚的硬件连接需要接近MCU侧。 三。如果MCU处于安全状态,则无法读取闪存中的任何信息。 最好的问候, 艾米 以上来自于百度翻译 以下为原文 1. Have you selected the right COM port in the "Set Environment"? 2. The hardware connection of programming mode related pins need be close to MCU side. 3. If the MCU was in security, you cannot read any information from the flash. Best regards, Amy |
760个成员聚集在这个小组
加入小组2159 浏览 1 评论
1908 浏览 1 评论
3729 浏览 1 评论
1840 浏览 6 评论
1588 浏览 1 评论
795浏览 2评论
552浏览 2评论
493浏览 2评论
452浏览 2评论
1309浏览 2评论
GMT+8, 2025-3-9 10:42 , Processed in 0.895577 second(s), Total 42, Slave 37 queries .
