你好,我想和FPGA接口,想听听我有什么选择。我正在查看数据表页21中的外部存储器接口部分5.6,我看到它有一个并行数据总线、并行地址总线和一些控制信号。我需要更多地了解这个问题,但是有人能告诉我这是不是可能?我希望能够向FPGA发送数据和接收数据。
谢谢, 乔 以上来自于百度翻译 以下为原文 Hello, I would like to interface to an FPGA and would like to hear what options I have. I was looking at the External Memory Interface section 5.6 in the Datasheet page 21 and I see that it has a parallel data bus, parallel address bus and some control signals. I need to look more into this but could anyone tell me if that is a possibility? I want to be able to send data to and receive data from the FPGA. Thanks, Joe |
760个成员聚集在这个小组
加入小组2167 浏览 1 评论
1910 浏览 1 评论
3734 浏览 1 评论
1843 浏览 6 评论
1590 浏览 1 评论
803浏览 2评论
559浏览 2评论
496浏览 2评论
454浏览 2评论
1321浏览 2评论
GMT+8, 2025-3-13 01:07 , Processed in 0.927526 second(s), Total 45, Slave 39 queries .
