电子发烧友论坛|
可能是一个新手问题,
我们有一个配置允许不同版本的附加工具,如modelsim,synplicity。 我们想知道是否有办法告诉Xilinx默认使用什么。 具体来说,我们有兴趣设置以下值: 首选项 - > ISE常规 - >集成工具 - >模型威廉希尔官方网站 模拟器 首选项 - > ISE常规 - >集成工具 - > Synplify Pro 似乎这些值可以使用$ HOME / .config / Xilinx / ISE.conf设置但是a)我没有真正成功地使用它并且b)它会设置每个USER的首选项,而我们需要设置每个首选项的首选项 项目,所以在检查HOME之前检查CWD的解决方案将更受欢迎。 谢谢你的任何指示 以上来自于谷歌翻译 以下为原文 Probably a newbie question, We have a configuration that allows for different versions of additional tools like modelsim, synplicity. We would like to know if there is a way to tell Xilinx what defaults to use. Specifically we are interested in setting the values of: Preferences->ISE General->Integrated Tools->Model Tech Simulator Preferences->ISE General->Integrated Tools->Synplify ProIt seems that these values can be set using $HOME/.config/Xilinx/ISE.conf however a) I was not really successful in using this and b) it would set the preferences per USER, whereas we need to set the preferences per project, so a solution that checks the CWD before it checks the HOME would be much more appreciated.Thanks for any pointers |
Project Navigator首选项完全基于用户。
为了根据项目设置首选项,您必须创建一个批处理脚本来操作$ HOME / .config / Xilinx / ISE.conf文件,然后调用ISE。 以上来自于谷歌翻译 以下为原文 The Project Navigator preferences are totally based on user. In order to set the preference based on project, you would have to create a batch script that manipulated the $HOME/.config/Xilinx/ISE.conf file and then called ISE. |
2429 浏览 7 评论
2830 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1288浏览 1评论
592浏览 1评论
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-27 01:14 , Processed in 1.132333 second(s), Total 48, Slave 42 queries .
