我正在收到警告信息
“警告:PROJECTMGMT-”D / TST / ADC200910CRO / ADCCRO200910_MAP.NCD“LINE0重复设计单元:MODULE | ADCCRO200910'” 点击之后点击确定或关闭它会导致ISE 9.2I关闭。 请问任何人请告诉我为什么所有这些东西都要来了,任何补救措施都要避免这种情况。 PLZ note adc200910cro和adccro200910是我项目的名称.. 以上来自于谷歌翻译 以下为原文 i am getting the warninng msg "WARNING:PROJECTMGMT-"D/TST/ADC200910CRO/ADCCRO200910_MAP.NCD"LINE0 DUPLICATE DESIGN UNIT:MODULE| ADCCRO200910'" AND AFTER THIS CLICKING ON OK OR CLOSING IT CAUSES THE ISE 9.2I TO SHUT DOWN. CAN ANYONE PLEASE TELL ME THAT WHY ALL THAT STUFF IS COMING AND ANY REMEDY TO AVOID THAT. plz note adc200910cro and adccro200910 are the names of my project.. |
4个回答
http://www.xilinx.com/support/download/index.htm
您可以转到存档选项卡,您可以找到9.2i的Service Pack 2 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 http://www.xilinx.com/support/download/index.htm You can go to archive tab and you can find the service pack 2 for 9.2i View solution in original post |
我知道涉及此消息的两个问题。
消息本身很烦人,但无害。 更多 关键问题涉及iMPACT。 什么时候 影响从Project Navigator运行,它写入一个不正确的条目 .ise文件并导致Project Navigator中的下一个进程运行到 表现得很糟糕(例如,挂起,崩溃)。 通常,下一个过程是 合成,它将设计的解析作为子程序运行,其中 生成惰性重复设计单元警告。 这应该在ISE 9.2i的Service pack2中修复。 有关详细信息,请参阅以下答案记录。 http://www.xilinx.com/support/answers/24159.htm http://www.xilinx.com/support/answers/25516.htm http://www.xilinx.com/support/answers/29119.htm 以上来自于谷歌翻译 以下为原文 There are two issues I know of involving this message. The message by itself is annoying but harmless otherwise. The more critical issue involves iMPACT. When impact is run from Project Navigator, it writes an incorrect entry to the .ise file and causes the next process run in Project Navigator to behave badly (e.g. hang, crash). Typically, the next process is synthesis, which runs a parse of the design as a subroutine, which produces the inert Duplicate Design Unit warning. This should be fixed in Service pack2 for ISE 9.2i. See the following Answer records for more details. http://www.xilinx.com/support/answers/24159.htm http://www.xilinx.com/support/answers/25516.htm http://www.xilinx.com/support/answers/29119.htm |
这意味着没有办法纠正这个错误我只需要使用一些预防措施,如单独使用冲击支架..
是否有任何更新可用于9.2i升级到Service Pack 2,其中您说问题已解决.. 感谢致敬 拉夫 以上来自于谷歌翻译 以下为原文 that means there is no way to correct this bug i just have to use some precautions such as using impact stand alone.. is there any updates avialable for 9.2i to upgrade it to service pack 2 in which you said the problem is resolved.. thanks and regards gaurav |
您可以转到存档选项卡,您可以找到9.2i的Service Pack 2 以上来自于谷歌翻译 以下为原文 http://www.xilinx.com/support/download/index.htm You can go to archive tab and you can find the service pack 2 for 9.2i |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 10:46 , Processed in 1.058371 second(s), Total 50, Slave 45 queries .
