嗨,
我想使用双频无线 - AC 8260来设计WiFI / BTH发生器。 我需要此模块使用的M.2连接器的电气/机械引脚排列(E型)。 在互联网上我找到M.2或M型连接器的机械规格, 但没有关于E型,机械式和首先的电气引出线。 所以我不知道USB 2.0接口的引脚,我对PCIe的引脚有疑问。 你能帮我吗 ? BR alfarf 以上来自于谷歌翻译 以下为原文 Hi, I would like to use a Dual Band Wireless - AC 8260 to design a WiFI/BTH generator. I need electrical/mechanical pinout of M.2 connector used by this module (type E). In internet I found mechanical specification of M.2 connector type M or Type B, but nothing about Type E, mechanical and first of all electrical pinout. So I do not know pin for USB 2.0 interface and I have doubts about pin for PCIe. Can you help me, please ? BR alfarf |
4个回答
您好alfarf,感谢您在此社区发布您的查询。在这种情况下,让我们进一步调查您的询问。我会尽快联系您。我希望这会有所帮助。最好的问候,Diego S.
以上来自于谷歌翻译 以下为原文 Hello alfarf, Thank you for posting your inquiry in this Community. In this case, let us investigate further into your inquiry. I will reach you back as soon as possible. I hope this helps. Best regards, Diego S. |
你好迭戈,
谢谢。 我期待着您的回音。 生物圈 Alfarf 以上来自于谷歌翻译 以下为原文 Hi Diego, Thank you. I am looking forward to hearing from you. BRs Alfarf |
您好alfarf,感谢您的耐心等待。在这种情况下,如果您正在寻找M.2连接器的电气/机械规格,您可以查看以下链接:https://pcisig.com/specifications/pciexpress/M .2_Specification /有关我们的英特尔®双频无线-AC 8260的电气/机械规格,请参阅https://intel.com/design中的产品数据表。您需要在那里创建一个新帐户, 为了能够访问该文档。我希望这有帮助.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello alfarf, Thank you for your patience. In this case, if you are looking for the electric/mechanical spec of the M.2 connector, you can check the following link: https://pcisig.com/specifications/pciexpress/M.2_Specification/ For the electric/mechanical specifications of our Intel® Dual Band Wireless-AC 8260, the information is available in the product data sheet found in https://intel.com/design You will need to create a new account in there, in order to get access to the document. I hope this helps. Regards, Diego S. |
jerry1978 发表于 2018-11-15 12:01 您好alfarf,我们只是想仔细检查您是否还需要进一步的帮助。请不要犹豫与我们联系。我希望尽快收到您的回复。最诚挚的问候,Diego S. 以上来自于谷歌翻译 以下为原文 Hello alfarf, We just wanted to double check if you still need further assistance. Please don’t hesitate on contacting us back. I hope to hear from you soon. Best Regards, Diego S. |
GMT+8, 2025-2-24 08:56 , Processed in 0.786728 second(s), Total 81, Slave 65 queries .
