我想在CYW43907中使用以太网和WiFi功能。我知道如何在项目中添加以太网和WFI接口。如果通过以太网接口将数据传输到43907,则通过43907 WiFi接口发送到其他设备。有两个部分。首先是来自以太网接口的43907个数据,并存储缓冲区A.第二个是缓冲区A的43907个数据,然后将数据传输到WiFi接口。我的理解正确吗?你有这个类型的例子项目吗?
以上来自于百度翻译 以下为原文 I want to use Ethernet and WiFi function together in CYW43907。I know to how to add the ethernet and Wfi interface in the project. If I transmit the datas to 43907 by the ethernet interface, then transmit to other device by the 43907 wifi interface. There are two parts. First is that 43907 recevice datas from the ethernet interface, and store the buffer A. Second is 43907 get datas from the buffer A, then transmit datas to the wifi interface. Is my understanding correct? Do you have this type example project? |
我们没有关于以太网WiFi桥的示例项目。可以考虑使用TCP跨接口进行数据传输。您可以先在43907上建立STA接口上的TCP客户端,然后在STA上与TCP服务器建立TCP连接。然后,可以在43907上在以太网接口上建立TCP服务器,并监听TCP端口。通过这个设置,您的TCP客户端设备将通过以太网发送数据到WICE TCP服务器。TCP数据包句柄将由服务器使用WICEDYTCPULIVE()来接收,数据缓冲区将使用WICDEXPACETEGETGETYLE DATA()从该句柄获得。WICCE TCP服务器将为该数据创建TCP包,并通过STA向TCP客户端发送该数据包。
以上来自于百度翻译 以下为原文 We do not have example project on ethernet-wifi bridge. You can consider using TCP for data transmission across interface. You can first set up a TCP client on STA interface on 43907 and set up a TCP connection over STA with your TCP server. You can then set up a TCP server on ethernet interface on 43907 and listen over a TCP port. With this setup, your TCP client device will send data over ethernet to WICED TCP server. The TCP data packet handle will be received by the server using wiced_tcp_receive() and data buffer will be obtained from this handle using wiced_packet_get_data(). WICED TCP server will create a TCP packet for this data and send this packet over STA to TCP client. |
763个成员聚集在这个小组
加入小组2192 浏览 1 评论
1936 浏览 1 评论
3758 浏览 1 评论
1861 浏览 6 评论
1604 浏览 1 评论
1069浏览 2评论
670浏览 2评论
513浏览 2评论
483浏览 2评论
1355浏览 2评论
GMT+8, 2025-4-9 11:59 , Processed in 1.024452 second(s), Total 44, Slave 39 queries .
