你好,小组成员。
在PSoC 6 BLE设置标签中有I/O CAPPABILITS。 如果这个设置被设置为键盘和显示器,该设备是否能够与键盘和显示器进行可互换的通信? 最好的问候 以上来自于百度翻译 以下为原文 Hello, group members. There are I / O capabillities in PSoC 6 BLE setting tabs. If this setting is set to Keyboard and Display, is the device capable of BLE communication with keyboard & display? Best Regards |
你好,SimimuHiRO-0Y167929,
在BLE设置选项卡中的I/O功能可以让您选择提供给其他配对设备的设备的能力。该信息然后与其他设备的IO能力一起使用,以选择适当的配对和密钥生成方案,如蓝牙规范版本4.2(VL 3,部分H2.2.3.5配对算法)中所描述的。 现在,选择“显示和键盘”让您在设备中有任何配对和密钥生成方案/算法。然而,如在BLE核心规范中所描述的,所选择的方案也将取决于配对中涉及的其他设备。 如果你对此有任何进一步的疑问,请告诉我。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Hello shimizu.hiro-00_1679296, The I/O capabilities in the BLE settings tab lets you select the capabilities of the device that is provided to the other pairing devices. This info is then used along with the other device's IO capabilities, to select an appropriate pairing and key generation scheme as described in BLUETOOTH SPECIFICATION Version 4.2 [Vol 3, Part H] 2.3.5 Pairing Algorithms. Now, selecting "Display and Keyboard" lets you have any pairing and key generation scheme/algorithm in your device. However, as described in the BLE core specification, the scheme selected will also depend on the other device involved in the pairing. Let me know if you have any further questions on this. Regards, Meenakshi Sundaram R |
757个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3688 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
461浏览 2评论
457浏览 2评论
412浏览 2评论
1101浏览 2评论
GMT+8, 2025-1-26 14:42 , Processed in 0.789605 second(s), Total 44, Slave 39 queries .
