我刚刚使用离线更新包“Xilinx_11.5_ISE_DS_nt.tar”修补了ISE WebPack 11.1。
但现在,我只能启动iMPACT,PlanAhead和其他配件。 ISE Project Navigator根本不起作用。 无论我如何点击桌面上的“Xilinx ISE 11”图标,都不会出现新的窗口,并且没有提示。 我该怎么调试呢? 哪个文件包含必要的错误日志? 消息由intronbbs编辑于04-11-2010 07:51 AMMessage由intronbbs编辑于04-11-2010 07:53 AM 以上来自于谷歌翻译 以下为原文 I just patched ISE WebPack 11.1 with the offline update package "Xilinx_11.5_ISE_DS_nt.tar". But now, I can only start iMPACT, PlanAhead and other accessories. ISE Project Navigator doesn't work at all. No matter how I click the icon of "Xilinx ISE 11" on desktop, no new window will appear, and it give me no prompt. How can I debug it? Which file contains necessary error log? Message Edited by intronbbs on 04-11-2010 07:51 AMMessage Edited by intronbbs on 04-11-2010 07:53 AM |
3个回答
我已经明白了这个问题。
当我安装更新包而不是更新文件时,它会删除D: Xilinx 11.1 common bin nt 中的许多文件,包括_pn.exe和其他基本文件。 我希望能得到Xilinx雇用的工程师的正式答复。 消息由intronbbs编辑于04-11-2010 10:59 AM消息由intronbbs编辑于04-11-2010 10:59 AM 以上来自于谷歌翻译 以下为原文 I have got clear to the problem. When I install the update package, instead of updating files, it deletes many files in D:Xilinx11.1commonbinnt, including _pn.exe and other essential files. I wish I could get an official answer from engineers employed by Xilinx. Message Edited by intronbbs on 04-11-2010 10:59 AMMessage Edited by intronbbs on 04-11-2010 10:59 AM |
听起来您在安装更新时可能没有足够的硬盘空间。
更新时,它会将所有要替换的文件移动到备份位置,以便您以后回滚安装。 听起来它已经完成了,但是在它可以替换所有这些文件之前耗尽硬盘空间。 您应该卸载上次更新(这是“开始”菜单中的一个选项),确保在执行此操作后它仍然有效,然后确保您至少有8 GB的可用磁盘空间。 一旦确定这一点,请再次尝试更新。 以上来自于谷歌翻译 以下为原文 It sounds like you may not have had enough hard drive space when installing the update. When you update it will move all the files that are being replaced to a backup location so you can roll back the installation at a later date. It sounds like it's done this, but then run out of hard drive space before it could replace all those files. You should uninstall the last update (this is an option from the Start Menu), make sure it still works after you do this and then make sure you've got at least 8 GB of free disk space. Once you're sure of this try the update again. |
我尝试准备更多可用磁盘空间,然后运行更新11.5的安装程序。
安装后,ISE Project Navigator这次工作。 那么,当磁盘空间耗尽时,您是否可以让安装程序弹出警报消息? 以上来自于谷歌翻译 以下为原文 I tried to prepare more free disk space and then ran the installation program of the update 11.5. After installation, ISE Project Navigator works this time. Well, may you let the installation program pop up an alerting message when disk space is exhausted? |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1682浏览 1评论
652浏览 0评论
1839浏览 0评论
562浏览 0评论
GMT+8, 2024-9-20 08:54 , Processed in 1.131661 second(s), Total 47, Slave 42 queries .
