嗨,
我在DevCloud中创建了一个新的conda环境,并从intel通道安装了tensorflow,如下所示: conda install -c intel tensorflow。 安装后,当我尝试导入tensorflow时,它给我一个错误。 附上错误的屏幕截图。 请帮忙。 GLIBC_Error.PNG 40.9 K. 以上来自于谷歌翻译 以下为原文 Hi, I created a new conda environment in DevCloud and installed tensorflow from intel channel as below: conda install -c intel tensorflow. After the installation, when I tried to import tensorflow, it threw me an error. Screenshot of the error is attached. Please help.
3个回答
您好Anju,感谢您与我们联系。请按照以下步骤解决问题-mkdir~ / libcd~ / libln -s /glob/supplementary-software/versions/glibc/glibc_2_28/lib/libm.so.6然后
通过执行以下操作导出LD_LIBRARY_PATH -export LD_LIBRARY_PATH =〜/ lib:$ LD_LIBRARY_PATH请告诉我们提供的解决方案是否有效。谢谢& 问候,Astha 以上来自于谷歌翻译 以下为原文 Hi Anju, Thank you for reaching out to us. Please follow the below steps for resolving the issue - mkdir ~/lib cd ~/lib ln -s /glob/supplementary-software/versions/glibc/glibc_2_28/lib/libm.so.6 Then export the LD_LIBRARY_PATH for it by doing the following - export LD_LIBRARY_PATH=~/lib:$LD_LIBRARY_PATH Please let us know if the resolution provided worked. Thanks & Regards, Astha |
jerry1978 发表于 2018-11-14 10:48 嗨Astha, 谢谢。 它解决了我的问题 以上来自于谷歌翻译 以下为原文 Hi Astha, Thank you. It solved my problem |
感谢您的确认Anju.We将关闭该主题。如有进一步的问题,请随时打开一个单独的主题。谢谢& 问候,Astha 以上来自于谷歌翻译 以下为原文 Thank you for the confirmation Anju. We will be closing the thread. For further issues, please feel free to open a separate thread. Thanks & Regards, Astha |
549浏览 0评论
GMT+8, 2025-1-24 20:17 , Processed in 0.440062 second(s), Total 46, Slave 41 queries .
