刚刚安装的MPLABX 4.10升级为4.05,Kuuntuu 17.10 LINUX.4.05运行良好,但4.10达到工作空间,与菜单栏和图标,但无论是关闭或挂起任何内部窗口打开。我已经尝试重新启动,卸载(包括旧版本),重新安装,但总是相同的问题。如果我从命令提示符开始,终端窗口显示:程序“Java”收到了X窗口系统错误。这可能反映了程序中的一个错误。错误是“RealDad图片(无效图片参数)”。在回到以前的版本……布瑞恩之前,有任何想法。
以上来自于百度翻译 以下为原文 Just installed MPLABX 4.10 as an upgrade to 4.05 on Kubuntu 17.10 Linux. 4.05 was working fine but 4.10 gets as far as the workspace, with menu bar and icons but then either shuts down or hangs before any internal windows open. I've tried rebooting, uninstalling (including old versions), reinstalling but always the same problem. If I start it from a command prompt, the terminal window shows: The program 'java' received an X Window System error. This probably reflects a bug in the program. The error was 'RenderBadPicture (invalid Picture parameter)'. Any ideas before I revert to the previous version.... Brian. |
嗨,我建议再次下载并重新安装它。类似的问题发生在我过去几次在Windows上。由于某些原因,下载的图像是不正确的…
以上来自于百度翻译 以下为原文 Hi, I suggest to download it again and reinstall it. similar issue happened to me in the past a couple of times on windows. for some reason the downloaded image was not correct... regards |
谢谢。我在其他帖子中使用了链接,因为官方下载页面仍然链接到4.05版本。我会一直等到微芯片下载页面被修复,以防我的副本有问题。布莱恩。
以上来自于百度翻译 以下为原文 Thanks. I used the link in one of the other posts as the official downloads page still links to the 4.05 version. I'll wait until the Microchip downloads page is fixed in case there is an issue with the copy I have. Brian. |
5370 浏览 9 评论
2100 浏览 8 评论
2004 浏览 10 评论
3277 浏览 3 评论
2312 浏览 5 评论
879浏览 1评论
768浏览 1评论
706浏览 1评论
764浏览 0评论
653浏览 0评论
GMT+8, 2025-3-6 19:38 , Processed in 1.006599 second(s), Total 46, Slave 41 queries .
