你好。我最近开始使用真正的冰来模拟PIC16LF18323设备。我以前使用过模拟器,基于这个经验,有一点惊讶地发现,显然这个设备的仿真只限于一个硬件断点。在Microchip网站上查找“设备调试功能”表明PIC16LF18323有一个“PROG/DATA”。“BP”和“运行时BPS”被列为“是”。术语“硬件断点”——在真正的ICE用户指南中使用——没有出现在设备调试特性列表中。因此,硬件断点相当于“PROG/DATA BP”或“运行时BP”,如果它是运行时BP,为什么不指定一个量而不是“是”。这意味着一个或无限数量?谢谢你的帮助。
以上来自于百度翻译 以下为原文 Hi. I recently started using REAL ICE to emulate a PIC16LF18323 device. I've used the simulator before and based upon that experience was a little surprised to discover that apparently emulation of this device is constrained to only one hardware breakpoint. Looking up the "Device Debug Features" on Microchip's web site indicated that the PIC16LF18323 has one "Prog/Data BP", and that "Runtime BPs" is listed as "Yes". The term "Hardware Breakpoint" - which is used in the REAL ICE User's Guide - doesn't appear in the Device Debug Features list. So, is a hardware breakpoint equivalent to a "Prog/Data BP" or a "Runtime BP", and if it's a Runtime BP why isn't a quantity specified instead of "Yes"... which could mean one or an unlimited number? Thanks for your help. |
“PROG/DATA BP”计数告诉你有多少。注意,硬件断点是PIC的一个特性,而不是调试器。你可以在程序位置上有软件断点,但是只有一个硬件断点会在数据上工作。许多PIC16F设备都有一个硬件。断点。一些PIC16F1XXX和PIC16F1XXXX设备有三个硬件断点。
以上来自于百度翻译 以下为原文 It is equivalent to both. The "Prog/Data BP" count tells you how many there are. Note, hardware breakpoints are a feature of the PIC, not of the debugger. You can have software breakpoints on program locations, but only a hardware breakpoint will work on data. Many PIC16F devices have a single hardware breakpoint. Some PIC16F1xxx and PIC16F1xxxx devices have three hardware breakpoints. |
因此,PROG/DATABRACKPONT和运行时断点都是硬件断点的两种类型。这两种断点类型有什么区别?我没有看到他们在真正的冰用户指南中描述。谢谢你帮助我理解。
以上来自于百度翻译 以下为原文 So, Prog/Data breakpoints and Runtime breakpoints are both types of hardware breakpoints. What's the difference between these two breakpoint types? I don't see them described in the REAL ICE User's Guide. Thanks for helping me to understand. |
5248 浏览 9 评论
2036 浏览 8 评论
1956 浏览 10 评论
3218 浏览 3 评论
2264 浏览 5 评论
787浏览 1评论
678浏览 1评论
604浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-27 18:53 , Processed in 1.097167 second(s), Total 45, Slave 40 queries .
