我想在PSoC 5上实现一个安全的引导加载程序。我的意思是,应用程序接收新的二进制文件,将其存储在MCU的闪存中,并且只有在上传完成后,才将控制转移到替换现有应用程序并重新启动MCU的加载器。
这有什么例子吗? 我看到在创建者4.2有一个新的SDK的引导加载程序。是否需要更新组件,或者可以用现有的引导加载程序完成吗? 谢谢, 马奥尔 以上来自于百度翻译 以下为原文 I would like to implement a safe bootloader on the PSoC 5. By that I mean that the application receives the new binary, stores it away in the flash memory of the MCU, and only after uploading is complete transfers control to a loader that replaces the existing application and restarts the MCU. Is there an example for this? I saw that in Creator 4.2 there's a new SDK for the bootloader. Is it required to update the components, or can it be done with the existing bootloader? Thanks, Maor |
你好,Maor,
我们没有根据您的要求的示例项目。为了确保Flash中的有效应用程序,可以使用双应用程序引导加载程序或金色图像引导加载程序。它们都允许两个可引导加载的应用程序驻留在Flash中。但是,每个应用程序都有一半的Flash可用于“标准”引导加载程序可用的东西。您可以在下面的文档中找到关于双应用程序和金色图像引导加载程序的更多细节。 Bootloader和Bootloady:CyPress半导体 AN7855-PSOC®3、PSoC 4和PSoC 5LP介绍BooLoad 以上来自于百度翻译 以下为原文 Hello Maor, We do not have example project as per your requirement. To ensure a valid application in the flash, you can make use of either Dual-application bootloader or Golden Image bootloader. Both of them allow two bootloadable applications to reside in flash. However, each application has one half of the flash available from what would have been available for a "standard" bootloader project. You can find more details on dual application and golden image bootloader in below documents. Bootloader and Bootloadable | Cypress Semiconductor AN73854 - PSoC® 3, PSoC 4, and PSoC 5LP Introduction to Bootloaders | Cypress Semiconductor |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 22:36 , Processed in 0.777682 second(s), Total 42, Slave 37 queries .
