大侠们,请问一下,我在运行ti的 ADC-CLA教程时,将原来的读取一路AD采样值改为两路,然后运行之后为什么程序一直停留在 Cla1ForceTask8andWait(); // Force CLA task 8. ??
原来的意图是想用CLA进行AD转换,主程序直接读取: 代码如下: //########################################################################### // Description: //! addtogroup f2803x_example_list //! CLA ADC (cla_adc)//! //! In this example ePWM1 is setup to generate a periodic ADC SOC. //! Channel ADCINA2 is converted. When the ADC begins conversion, //! it will assert ADCINT2 which will start CLA task 2. //! //! Cla Task2 logs 20 ADCRESULT1 values in a circular buffer. //! When Task2 completes an interrupt to the CPU clears the ADCINT2 flag. //! //! b Watch b Variables n //! - VoltageCLA - Last 20 ADCRESULT1 values //! - ConversionCount - Current result number //! - LoopCount - Idle loop counter // // //########################################################################### // $TI Release: F2803x C/C++ Header Files and Peripheral Examples V126 $ // $Release Date: November 30, 2011 $ //########################################################################### #include "DSP28x_Project.h" // Device Headerfile and Examples Include File #include "CLAShared.h" #include #include // Prototype statements for functions found within this file. __interrupt void cla1_isr2(void); // Global variables used in this example: #pragma DATA_SECTION(ConversionCount0, "Cla1ToCpuMsgRAM"); #pragma DATA_SECTION(ConversionCount1, "Cla1ToCpuMsgRAM"); #pragma DATA_SECTION(VoltageCLA, "Cla1ToCpuMsgRAM"); #pragma DATA_SECTION(CurrentCLA, "Cla1ToCpuMsgRAM");// Uint16 ConversionCount0; Uint16 ConversionCount1; Uint16 LoopCount; Uint16 VoltageCLA[NUM_DATA_POINTS]; Uint16 CurrentCLA[NUM_DATA_POINTS];// Uint16 x,y,a,b; int i; // These are defined by the linker file extern Uint16 Cla1funcsLoadStart; extern Uint16 Cla1funcsLoadEnd; extern Uint16 Cla1funcsRunStart; main() [ // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2803x_SysCtrl.c file. InitSysCtrl(); // Step 2. Initialize GPIO: // This example function is found in the DSP2803x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Skipped for this example // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2803x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2803x_DefaultIsr.c. // This function is found in DSP2803x_PieVect.c. InitPieVectTable(); // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. EALLOW; // This is needed to write to EALLOW protected register PieVectTable.CLA1_INT2 = &cla1_isr2; EDIS; // This is needed to disable write to EALLOW protected registers // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2803x_InitPeripherals.c // InitPeripherals(); // Not required for this example InitAdc(); // For this example, init the ADC // Step 5. User specific code, enable interrupts: // Enable ADCINT1 in PIE PieCtrlRegs.PIEIER11.bit.INTx2 = 1; // Enable INT 11.2 in the PIE (CLA Task2) IER |= M_INT11; // Enable CPU Interrupt 11 EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM // Copy CLA code from its load address to CLA program RAM // // Note: during debug the load and run addresses can be // the same as Code Composer Studio can load the CLA program // RAM directly. // // The ClafuncsLoadStart, ClafuncsLoadEnd, and ClafuncsRunStart // symbols are created by the linker. memcpy((uint16_t *)&Cla1funcsLoadStart,(uint16_t *)&Cla1funcsRunStart, (unsigned long)&Cla1funcsLoadEnd); // Initialize the CLA registers EALLOW; Cla1Regs.MVECT3 = (Uint16) (&Cla1Task3 - &Cla1Prog_Start)*sizeof(Uint32); // Cla1Regs.MVECT2 = (Uint16) (&Cla1Task2 - &Cla1Prog_Start)*sizeof(Uint32); Cla1Regs.MVECT8 = (Uint16) (&Cla1Task8 - &Cla1Prog_Start)*sizeof(Uint32); Cla1Regs.MPISRCSEL1.bit.PERINT2SEL = CLA_INT2_ADCINT2; // ADCINT2 starts Task 2 Cla1Regs.MMEMCFG.bit.PROGE = 1; // Map CLA program memory to the CLA Cla1Regs.MCTL.bit.IACKE = 1; // Enable IACK to start tasks via software Cla1Regs.MIER.all = (M_INT8 | M_INT2 | M_INT3); // Enable Task 8 and Task 2 Cla1ForceTask8andWait(); // Force CLA task 8. // This will initialize ConversionCount to zero AdcRegs.ADCCTL1.bit.INTPULSEPOS = 0; // ADCINT trips when ADC begins conversion AdcRegs.INTSEL1N2.bit.INT2E = 1; // Enable ADCINT2 AdcRegs.INTSEL1N2.bit.INT2CONT = 0; // Disable ADCINT2 Continuous mode AdcRegs.INTSEL1N2.bit.INT2SEL = 1; // setup EOC1 to trigger ADCINT2 to fire AdcRegs.ADCSOC1CTL.bit.CHSEL = 1; // set SOC1 channel select to ADCINA2 AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 5; // set SOC1 start trigger on EPWM1A AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; // set SOC1 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) AdcRegs.ADCSOC2CTL.bit.CHSEL = 2; // set SOC1 channel select to ADCINA2 AdcRegs.ADCSOC2CTL.bit.TRIGSEL = 5; // set SOC1 start trigger on EPWM1A AdcRegs.ADCSOC2CTL.bit.ACQPS = 6; // set SOC1 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) EDIS; // Assumes ePWM1 clock is already enabled in InitSysCtrl(); EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; EDIS; EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.CMPA.half.CMPA = 0x2EE; // Set compare A value EPwm1Regs.TBPRD = 0x5DC; // Set period for ePWM1 - this will determine the sampling frequency(20KHz) EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; // Wait for ADC interrupt for(;;) [ LoopCount++; x = VoltageCLA[0]; y = CurrentCLA[0]; ] ] // This interrupt occurs when CLA Task 2 completes __interrupt void cla1_isr2() [ AdcRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; // Clear ADCINT2 flag reinitialize for next SOC PieCtrlRegs.PIEACK.all = 0xFFFF; ] CLA.ASM: ;// TI File $Revision: /main/8 $ ;// Checkin $Date: October 7, 2010 11:41:29 $ ;//########################################################################### ;// ;// FILE: DSP2803x_Cla.asm ;// ;// TITLE: CLA Assembly Code. ;// ;// This file contains the CLA assembly code. When building the project ;// containing this file, use C28x codegen V5.2.0 or later with the switch ;// --cla_support=cla0 ;// ;//########################################################################### ;// $TI Release: F2803x C/C++ Header Files and Peripheral Examples V126 $ ;// $Release Date: November 30, 2011 $ ;//########################################################################### ;// Include variables and constants that will be shared in the ;// C28x C-code and CLA assembly code. This is accomplished by ;// using .cdecls to include a C-code header file that contains ;// these variables and constants .cdecls C,LIST,"CLAShared.h" ;// To include an MDEBUGSTOP (CLA breakpoint) as the first instruction ;// of each task, set CLA_DEBUG to 1. Use any other value to leave out ;// the MDEBUGSTOP instruction. CLA_DEBUG .set 1 ;// CLA code must be within its own assembly section and must be ;// even aligned. Note: since all CLA instructions are 32-bit ;// this alignment naturally occurs and the .align 2 is most likely ;// redundant .sect "Cla1Prog" .align 2 _Cla1Prog_Start: _Cla1Task1: MSTOP MNOP MNOP MNOP _Cla1T1End: _Cla1Task2: .if CLA_DEBUG == 1 MDEBUGSTOP .endif ;============================================== ; This task logs the last NUM_DATA_POINTS ; ADCRESULT1 values in the array VoltageCLA ; ; When the last element in the array has been ; filled, the task will go back to the ; the first element. ; ; Before starting the ADC conversions, force ; Task 8 to initialize the ConversionCount to zero ; ;============================================== MMOVZ16 MR0, @_ConversionCount0 ;1 Current Conversion MMOV16 MAR1, MR0, #_VoltageCLA ;2 Point to VoltageCLA[ConversionCount] MUI16TOF32 MR0, MR0 ;3 Convert count to float32 MADDF32 MR0, MR0, #1.0 ;4 Add 1 to conversion count MCMPF32 MR0, #NUM_DATA_POINTS.0 ;5 Compare count to max MF32TOUI16 MR0, MR0 ;6 Convert count to Uint16 MNOP ;7 Wait till I8 to read result MMOVZ16 MR2, @_AdcResult.ADCRESULT1 ;8 Read ADCRESULT1 MMOV16 *MAR1, MR2 ; Store ADCRESULT1 MBCNDD _RestartCount0, GEQ ; If count >= NUM_DATA_POINTS MMOVIZ MR1, #0.0 ; Always executed: load MR1 with 0 MNOP MNOP MMOV16 @_ConversionCount0, MR0 ; If branch not taken, store current count MSTOP _RestartCount0 MMOV16 @_ConversionCount0, MR1 ; If branch taken, restart count MSTOP MNOP MNOP MNOP _Cla1T2End: _Cla1Task3: .if CLA_DEBUG == 1 MDEBUGSTOP .endif ;============================================== ; This task logs the last NUM_DATA_POINTS ; ADCRESULT1 values in the array VoltageCLA ; ; When the last element in the array has been ; filled, the task will go back to the ; the first element. ; ; Before starting the ADC conversions, force ; Task 8 to initialize the ConversionCount to zero ; ;============================================== MMOVZ16 MR0, @_ConversionCount1 ;1 Current Conversion MMOV16 MAR1, MR0, #_CurrentCLA ;2 Point to VoltageCLA[ConversionCount] MUI16TOF32 MR0, MR0 ;3 Convert count to float32 MADDF32 MR0, MR0, #1.0 ;4 Add 1 to conversion count MCMPF32 MR0, #NUM_DATA_POINTS.0 ;5 Compare count to max MF32TOUI16 MR0, MR0 ;6 Convert count to Uint16 MNOP ;7 Wait till I8 to read result MMOVZ16 MR2, @_AdcResult.ADCRESULT2 ;8 Read ADCRESULT1 MMOV16 *MAR1, MR2 ; Store ADCRESULT1 MBCNDD _RestartCount1, GEQ ; If count >= NUM_DATA_POINTS MMOVIZ MR1, #0.0 ; Always executed: load MR1 with 0 MNOP MNOP MMOV16 @_ConversionCount1, MR0 ; If branch not taken, store current count MSTOP _RestartCount1 MMOV16 @_ConversionCount1, MR1 ; If branch taken, restart count MSTOP MNOP MNOP MNOP _Cla1T3End: _Cla1Task4: MSTOP MNOP MNOP MNOP _Cla1T4End: _Cla1Task5: MSTOP MNOP MNOP MNOP _Cla1T5End: _Cla1Task6: MSTOP MNOP MNOP MNOP _Cla1T6End: _Cla1Task7: MSTOP MNOP MNOP MNOP _Cla1T7End: _Cla1Task8: ;============================================== ; This task initializes the ConversionCount ; to zero ;============================================== MMOVIZ MR0, #0.0 MMOV16 @_ConversionCount0, MR0 MMOVIZ MR0, #0.0 MMOV16 @_ConversionCount1, MR0 MSTOP _Cla1T8End: _Cla1Prog_End: .end .include "CLAShared.h" 不清楚哪里出了问题,实际运行中没办法读取到AD的值。 |
1 个讨论
Sam,
把memcpy代码修改一下,原代码有误,改成下面。 // The ClafuncsLoadStart, ClafuncsLoadEnd, and ClafuncsRunStart // symbols are created by the linker. memcpy((uint16_t *)&Cla1funcsRunStart,(uint16_t *)&Cla1funcsLoadStart, (unsigned long)&Cla1funcsLoadSize); 另外,应该让EOC2触发ADCINT2,这样你读才能够读到最新的ADC SOC2的值 AdcRegs.INTSEL1N2.bit.INT2SEL = 2; // setup EOC2 to trigger ADCINT2 to fire Eric - ERIC |
1503 浏览 1 评论
TI的DSP0049在PHS载入值跨过CMPA事件会产生丢波现象
775 浏览 0 评论
1164 浏览 1 评论
1347 浏览 0 评论
802 浏览 1 评论
592浏览 29评论
1586浏览 23评论
644浏览 20评论
583浏览 14评论
480浏览 13评论
GMT+8, 2025-7-13 14:41 , Processed in 1.109306 second(s), Total 59, Slave 47 queries .
