MacBook Pro 2018在其原生视网膜屏幕和我可以测试的所有外接显示器上都会造成眼睛疲劳(使用ThinkPad T440s和戴尔Inspiron可以很好地查看)
症状:难以集中注意力,眼睛后部疼痛,头部拉伤 - (也感觉它在我的手中 - 我知道这很奇怪) 计算机使用模式:正常10-6使用,符合人体工程学的房间,监视器后面没有窗户或屏幕反射。 监视器我测试了我的新MacBook 2018: 较旧的显示器: 富士通西门子 - Scaleoview L22W 三星Syncmaster 205BW 较新的显示器: 戴尔U2518D 明基BL 3200 - 我的主要日常显示器 LG 27UK850-W 所有上述显示器都会导致我的MacBook Pro 2018出现眼睛不适和紧张。 以上所有显示器在使用时都不会引起我的眼睛不适: ThinkPad T440s - 我的主要日常机器 戴尔Inspiron 15r 自带PC,显示器采用NVidia 1050ti驱动 我还有13“MacBook Pro 2011 - 这不会导致我的任何眼睛疲劳(本机屏幕和外部屏幕都很好) 我的Macbook Pro显示驱动程序规格: 英特尔UHD图形630 Radeon Pro 555X 可能是什么原因在这里,我真的在我的智慧结束。我一直在谷歌搜索,有人说它是英特尔芯片的抖动 - 它可能是吗? 谢谢, Janno 以上来自于谷歌翻译 以下为原文 MacBook Pro 2018 is causing eye strain both on its native retina screen and on all the external monitors I could test it with (that are fine to look at for me with ThinkPad T440s and Dell Inspiron) Symptoms: hard to focus, pain at the back of the eyes, head strain - (also feel it in my hands -it's weird i know) Computer usage patterns: normal 10-6 usage, ergonomically lit room, no windows behind monitors or reflections on screen. Monitors I tested my new MacBook 2018 with: Older monitors: Fujitsu Siemens - Scaleoview L22W Samsung Syncmaster 205BW Newer monitors: Dell U2518D BenQ BL 3200 - my main daily monitor LG 27UK850-W All of the above monitors caused eye-discomfort and strain with my MacBook Pro 2018. All of the above monitors did not cause my eye discomfort when using them with: ThinkPad T440s - my main daily machine Dell Inspiron 15r Self built PC with display driven with NVidia 1050Ti I also have 13” MacBook Pro 2011 - and that does not cause my any eye strain (both good with native screen and with external screens) My Macbook Pro display driver specs: Intel UHD Graphics 630 Radeon Pro 555X What could be the cause here, I'm really at my wits end here. I've been googling around and some say it's the dithering from Intel chips - could it be it? Thanks, Janno |
HelloJannoKilling感谢您加入英特尔®社区,请允许我帮助您处理此案例。在查看您提供的信息后,我发现了以下主题“眼睛疲劳”(https://communities.intel.com/thread/53309
)请查看并查看它与您遇到的问题相同。 请记住,Apple *已要求所有与其产品相关的查询都需要提交给他们。 最好的选择是联系Apple *,以便他们为此问题提供正确的故障排除步骤。 此链接将为您提供其联系信息https://support.apple.com/contact。 希望他的帮助。 此致,莱昂纳多C. 以上来自于谷歌翻译 以下为原文 Hello JannoKilling Thank you for joining the Intel® community, allow me to help you with the case. After reviewing the information that you have provided I have found the following thread “eye strain” (https://communities.intel.com/thread/53309) please reviewed and see it is the same issue that you are having. Bear in mind that Apple* has requested that all inquiries related to their products need to be referred to them. The best option would be contacting Apple* so they can provide proper troubleshooting steps for this issue. This link will give you their contact information https://support.apple.com/contact. Hope his help. Regards, Leonardo C. |
jerry1978 发表于 2018-11-13 12:50 我现在从当地的Apple高级商店了解到,如果一个人的眼睛对低频LED背光PWM闪烁很敏感,那么你的眼睛很可能会受到新款2018 MacBook Pro抖动的影响。 到目前为止,我还没有找到一种方法来禁用OSX上的抖动。所以我将返回我的新机器并尝试2015款,因为人们发现它不会造成眼睛疲劳。 感谢您抽出宝贵时间回答! 秋天快乐! 以上来自于谷歌翻译 以下为原文 I have now learned from my local Apple premium shop that if a persons eyes are sensitive to low frequency LED backlight PWM flickering, then there is a high chance that your eyes will be affected by the dithering on the new 2018 MacBook Pro. So far I have not found a way to disable the dithering on OSX. So I'll be returning my new machine and trying out the 2015 model as people have found it does not cause eye strain as much. Thanks for taking the time to answer! Happy Autumn! |
572浏览 0评论
GMT+8, 2025-2-9 10:44 , Processed in 0.587783 second(s), Total 44, Slave 39 queries .
