嘿。
所以我购买了一个入口CPU,附带一个附带的游戏包。 我被要求输入我从供应商收到的主密钥:https://starterpack.intel.com/。 我输入主密钥并点击提交只发现提交按钮根本没有做任何事情。 试过支持和FAQ页面,两者都破了。 有什么方法可以兑换我的包装或这是一个骗局吗? 以上来自于谷歌翻译 以下为原文 Hey. So I purchased a inlet CPU, which came with an included gaming pack. I was required to input a master key which i had received from the vendor into: https://starterpack.intel.com/ . I input the master key and hit submit only to find the submit button doesn't do anything at all. Tried the support and FAQ pages, both also broken. Is there some way i can redeem my pack or was this all a scam? |
为什么你不仅要耐心等待英特尔员工处理这个问题?
并且,对于你开始使用SCAM这个词有点荒谬。 文件 以上来自于谷歌翻译 以下为原文 Why do you not just be patient and let the Intel staff deal with this? And, for you to start using the word SCAM is a bit ridiculous. Doc |
您好Silent_CA,感谢您加入英特尔社区。我向您发送了一条私信,以便我提供我为您创建的案例编号。
请检查您的收件箱.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello Silent_CA, Thank you for joining the Intel Communities. I sent to you a private message so I can provide a case number I created for you. Please check your inbox. Regards, Fred D. |
573浏览 0评论
GMT+8, 2025-2-12 02:27 , Processed in 0.483368 second(s), Total 44, Slave 39 queries .
