你好。
我使用Microsoft Network Monitor 3.4捕获流量并使用英特尔双频无线-AC 8260卡(WMM认证,驱动程序19.10.13.1)获得奇怪的行为,连接到具有QoS启用的思科接入点(2702I)。 IP数据包在两个方向(上行和下行)都标记为应用程序的语音流量DSCP 46,但是: - 在下游,接入点将Qos控制优先级(UP)设置为6(AC_VO语音):这是正确的配置 - 在上游,没有任何标记:这是我的问题的目的 无线网卡能否设置WMM UP字段? 有人有更多相关信息吗? 以上来自于谷歌翻译 以下为原文 Hello. I capture traffic with Microsoft Network Monitor 3.4 and get a strange behavior with an Intel Dual Band Wireless-AC 8260 card (WMM certified, driver 19.10.13.1), connected to a Cisco Access point (2702I) with QoS enable. IP packet are well tagged on both direction (up and downstream) as DSCP 46 for voice traffic by the application, but: - in downstream, Qos Control Priority (UP) is set to 6 (AC_VO voice) by the access point: this is a correct comportement - in upstream, no mark of any : this is the purpose of my question Does the wireless card able to set the WMM UP field? Is anybody have more information about this? |
6个回答
您好Remix,感谢您加入英特尔社区。让我对此进行进一步的研究并回复您。
我会尽快在这个帖子上发布信息.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello Remix, Thank you for joining the Intel Communities. Let me do further research about this and come back to you. I will post information on this thread as soon as I have it. Regards, Fred D. |
您好Remix,您是否有可能向我们发送您已经显示问题的网络流量捕获?问候,Fred D.
以上来自于谷歌翻译 以下为原文 Hello Remix, Is it possible for you to send to us the network traffic capture you have showing the issue? Regards, Fred D. |
你好。 是的,我上传了上游和下游帧捕获的截图。 问候。 Upstream.PNG 47.8 K. Downstream.PNG 62.1 K. 以上来自于谷歌翻译 以下为原文 Hello. Yes, I upload screenshot of a capture for upstream and downstream frames. Regards.
您好Remix,感谢您发送给我的其他信息。 一旦我有任何信息,我会尽快与您联系.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello Remix, Thanks for the additional information you sent to me. I will contact you back as soon as I have any information available. Regards, Fred D. |
您好Remix,感谢您加入英特尔社区。您是否可以提供无线(OTA)数据包捕获,以便我们进一步调查?问候,Fred D.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello Remix, Thank you for joining the Intel Communities. Is it possible for you to provide Over-the-Air (OTA) packet captures so we can investigate further? Regards, Fred D. Intel Customer Support Technician Under Contract to Intel Corporation |
您好RemixI正在检查您的案例,并想知道您是否需要进一步的帮助。 如果是这样,请不要犹豫回复.Regards,Leonardo C.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello Remix I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
GMT+8, 2025-2-24 23:45 , Processed in 0.881521 second(s), Total 85, Slave 69 queries .
