The AS3UA6313CR is a switches combo of High-Speed Data/Hi-Fi Audio and Side Band Use (SBU). It
operates dual power supplies of VBUS and VBAT, either of which can power-up the chip. The Audio path is with low distortion, high swing capability that features Ron of 1.2Ω (typical) at VBAT=3.3V. With very sound THD+N performance, it is an ideal device for Hi-Fi system applications. The USB path bandwidth is wide enough (>900MHz) to pass high-speed USB 2.0 differential signals (480 Mb/s) with good signal integrity. The Side Band Use (SBU) configures internal switches to Ground and MIC connections on a headphone connector. The Ground switch has a low Ron of 0.3Ω (typical) to minimize voltage drop across it, preventing undesired increase in headphone ground reference voltage. Furthermore, a GND sense path supports quasidifferential amplifier architectures, which helps reduce cross-talk between R and L and improve sound quality. In addition, SBU ports (40MHz bandwidth) can be configured as UART Tx/Rx ports or to transmit eDP AUX signals (1MHz).
USB音频方案,USB声卡方案,typec耳机方案 |
1970 浏览 3 评论
说是一款高频高压三相channel transmitter专业词我不知道怎么翻译
1677 浏览 1 评论
电路分析:为什么R6处输出电压为8V,R6和Q1拆掉是这样?
823 浏览 1 评论
1227 浏览 1 评论
1294 浏览 1 评论
GMT+8, 2024-9-20 15:04 , Processed in 1.014716 second(s), Total 39, Slave 30 queries .
