嗨,因为我无法获得任何ifn003v1板,我买了一台带有STM32f4discovery的EVAL6230QR,我试图让它们与ST FOC库ST MC Workbench和MAXXON电机(EC-max 283833)一起工作。
我正在尝试运行演示代码,即反复启动和停止电机的代码。但事实证明,它因故障而重置。通过调试我可以发现错误定义为MC_SPEED_FDBK,我试图找出原因。 St MC工作台是否设置错误?我接错了什么?我将非常感谢您正确设置参数的任何帮助。 在此先感谢,最诚挚的问候 以上来自于谷歌翻译 以下为原文 Hi, as I couldn´t get any ifn003v1 board, I bought an EVAL6230QR with an stm32f4discovery, and I´m trying to get them work together with the ST FOC library the ST MC Workbench and a MAXXON motor (EC-max 283833). I´m trying to run the demo code, the one that starts and stops the motor repeatedly. But it turns out that it resets because of a fault. by debugging I could find that the error is defined as MC_SPEED_FDBK, and I was trying to find out why. Is the St MC workbench set wrong? I´m wiring something wrong? I will appreciate any help to set the parameters correctly. Thanks in advance,Best Regards |
再见
请看一下[DEAD LINK /public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/Flat.aspx?RootFolder=/public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and% 20Software / ST%20MC%20Workbench%20%图2b%20ST%20FOC%20library&安培; FolderCTID = 0x01200200770978C69A1141439FE559EB459D758000CE106710FFA6574FB92BFFEFCE2DD930&安培; TopicsView = HTTPS://my.st.com/public/STe2ecommunities/motordriver_ics/Lists/Motor%2520Control%2520Firmware%2520and% 2520Software / AllItems.aspx& currentviews = 8]这里尝试不要复制帖子。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Please take a look at [DEAD LINK /public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/Flat.aspx?RootFolder=/public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/ST%20MC%20Workbench%20%2b%20ST%20FOC%20library&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000CE106710FFA6574FB92BFFEFCE2DD930&TopicsView=https://my.st.com/public/STe2ecommunities/motordriver_ics/Lists/Motor%2520Control%2520Firmware%2520and%2520Software/AllItems.aspx¤tviews=8]here an try don't duplicate the posts. Ciao Gigi |
2779 浏览 1 评论
3251 浏览 1 评论
1824 浏览 1 评论
3667 浏览 6 评论
6062 浏览 21 评论
1347浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
468浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
214浏览 2评论
GMT+8, 2025-1-11 16:32 , Processed in 0.922924 second(s), Total 44, Slave 39 queries .
