您好,我想对lsm9ds1进行自检。
有没有文件可以解释如何做到这一点? 我找到了一些消息来源但没有正式的 如果没有官方档案,我有一些问题: 传感器在自检时是否不能运动? 传感器必须处于特定位置吗? 如何对磁力计进行自检? 谢谢 Yair Sarid #self-test#lsm9ds1 以上来自于谷歌翻译 以下为原文 Hello, I want to do a self test to lsm9ds1. Is there any file that explain how to do it? I found some sources but nothing official. If there is not official file, i have some questions: Is the sensor can't be in motion at the time of the self test? Is the sensor must be in specific position? How to make self test to the magnetometer? Thank you Yair Sarid #self-test #lsm9ds1 |
3个回答
你好,
它也不是ST的“官方”信息,但我正在研究LSM9DS1,而对于磁力计自检,我使用的是LIS3MDL磁力计的程序。我用于磁力计的程序在下面解释 /external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fresource%2Fen%2Fapplication_note%2Fdm00136626.pdf 。不幸的是,LSM9DS1磁力计和LIS3MDL测试结果的范围可能不同。我在这个论坛上问了一个问题: https://community.st.com/0D50X00009XkXStSAN 回复中还有一些提示: https://community.st.com/message/10108 不幸的是,正如评论中所提到的,如果我们必须采取差异'NOST_DATA - ST_DATA'或',我也不清楚 ST_DATA - NOST_DATA' 检查标志。 最好, 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello, It is also not 'official' information from ST, but I am working on LSM9DS1, and for the magnetometer self-test I am using the procedure of the LIS3MDL magnetometer. The procedure I am using for the magnetometer is explained in the /external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fresource%2Fen%2Fapplication_note%2Fdm00136626.pdf . Unfortunately, it is possible that the ranges for testing the results are different between the LSM9DS1 magnetometer and the LIS3MDL. I asked on this forum a question about that: https://community.st.com/0D50X00009XkXStSAN There is also some hints in the response to: https://community.st.com/message/10108 Unfortunately, as mentioned in a comment, it is not clear also for me if we have to take the difference 'NOST_DATA - ST_DATA' or ' ST_DATA - NOST_DATA' to check the sign. Best, David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
对不起,自测程序无法在论坛上分享。
在自检期间,传感器不能运动。 自测期间的位置无关紧要。 以上来自于谷歌翻译 以下为原文 I'm sorry, the self-test procedure cannot be shared on the forum. The sensor can't be in motion during the self-test. The position during the self-test doesn't matter. |
大家好,
david.meignan is是正确的,上次官方信息证实LSM9DS1内部的磁力计正好是LIS3MDL,您可以使用http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe /a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:content/translations/en.DM00136626.pdf 用于LSM9DS1磁力仪自测包括极限。 问候, 切赫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello all, david.meignan ‌ is correct, last official information confirmed that magnetometer inside LSM9DS1 is exactly LIS3MDL and you can use http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe/a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:content/translations/en.DM00136626.pdf for LSM9DS1 magnetometer selftest including the limits. Regards, Petr Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 10:31 , Processed in 1.058320 second(s), Total 52, Slave 46 queries .
