我刚刚下载并安装了MPLAB X V4.10在我的MacBook Pro上。然后我安装了Microchip和谐配置器V2.0.4.0,然后尝试打开我的和声项目。我收到一个错误信息:MPLAB协调器初始化失败。我不知道该怎么做才能纠正这个错误。建议?提前感谢任何帮助!——Don
以上来自于百度翻译 以下为原文 I just downloaded & installed MPLAB X v4.10 on my MacBook Pro. I then installed Microchip HARMony Configurator v2.0.4.0. I then tried to open my Harmony project. I received an error message stating: MPLAB Harmony Configurator failed to initialize. I am not sure what to do to correct this. Suggestions? Thanks in advance for any help! --Don |
3个回答
我安装了2.0.4.0。我卸载了它并回到了V1.11。MPLAB X V4.10仍然未能初始化MHC……我切换回V3.00 IDE和MHC V1.0.100&AMP再次打开IDE。MHC无法再次初始化!我放弃!我错过了什么?
以上来自于百度翻译 以下为原文 I installed 2.0.4.0. I uninstalled it & went back to v1.11. MPLAB X v4.10 still failed to initialize MHC... I switched back to v3.00 IDE & MHC v1.0.10.0 & opened the IDE again. The MHC failed to initialize again! I give up! What am I missing? |
嗨,MHC插件必须符合和声版本,否则你会得到这种类型的消息。不要使用和声V1.XX,因为它已经被和声V2.XXX取代了。我有下列版本工作正常:MPLAB X V4.10和声V2.05.01MHC插件V2.0.5.2确保MHC插件MA和谐,安装它从和谐目录:C:Microchip 和谐 V2Y05Y001 实用程序MHC COMMicroPC-MPLAB-模块-MHC NBM遵循以下教程:http://MicroChIPDealth.com /和谐:MHC安装
以上来自于百度翻译 以下为原文 Hi, MHC plugin must match the Harmony version otherwise you'll get this type of message. Do not use Harmony v1.xx because it has been replaced by Harmony v2.xx currently I have the following versions which work properly : MPLAB X v4.10 Harmony v2.05.01 MHC plugin v2.0.5.2 To be sure that the MHC plugin matches Harmony, install it from the Harmony directory : c:microchipharmonyv2_05_01utilitiesmhccom-microchip-mplab-modules-mhc.nbm follow the tutorial here : http://microchipdeveloper.com/harmony:mhc-installation regards |
5323 浏览 9 评论
2076 浏览 8 评论
1982 浏览 10 评论
3254 浏览 3 评论
2293 浏览 5 评论
835浏览 1评论
732浏览 1评论
674浏览 1评论
728浏览 0评论
622浏览 0评论
GMT+8, 2025-2-3 13:50 , Processed in 1.041621 second(s), Total 52, Slave 45 queries .
