亲爱的所有人,主题中的产品不可能以最小的大小编译。用-OS生成12680字节的代码。如果我检查“干净并用Pro比较构建……”我可以看到我可以达到10024字节的大小。我找不到理由。我不能用PRO模式编译,有什么建议吗?许可证和HPA是注册和安装的,许可证是有效的。状态的提示是:Microchip XC许可证管理器版本:2.22许可证路径:C:StudioDeaMicrochip xCLM/许可证/产品:XC32类型:工作站版本:1.1模式:CPP密钥:xxxx xxxxxxxxxxxx产品:rLMyROAM类型:wOrkStand版本:1模式:?谢谢您!
以上来自于百度翻译 以下为原文 Dear all, the product in the subject does not compile at minimum possible size. With -Os it generates 12680 bytes code. If I check "CLean and Build with Pro comparison..." I can see that I could achieve 10024 bytes of size. I can't find a reason for that. I can't compile in PRO mode, it seems. Any suggestion? License and HPA are registered and installed and the license is valid. The prompt of the status is: Microchip XC License Manager Version: 2.22 License Path: C:ProgramDataMicrochipxclm/license/ Product: xc32 Type: Workstation Version: 1.1 Mode: cpp Key: xxxx-xxxx-xxxx-xxxx Product: rlm_roam Type: Workstation Version: 1.0 Mode: ? Thank you! |
您可能需要启用MIPS16或MIMPIPS模式中的建筑物。检查XC32 GCC和XC32-G++设置的选项,这样做。
以上来自于百度翻译 以下为原文 You probably need to enable building in either MIPS16 or microMIPS mode. Check the xc32-gcc and xc32-g++ settings for an option to do this. |
5341 浏览 9 评论
2084 浏览 8 评论
1988 浏览 10 评论
3265 浏览 3 评论
2301 浏览 5 评论
846浏览 1评论
741浏览 1评论
683浏览 1评论
739浏览 0评论
631浏览 0评论
GMT+8, 2025-2-12 14:11 , Processed in 1.092317 second(s), Total 45, Slave 39 queries .
