我用的是STM32F429芯片
首先贴代码: void ADC1_CH6_DMA_Config(void) { ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; DMA_InitTypeDef DMA_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); // DMA_DeInit(DMA2_Stream0); /* DMA2 Stream0 channe0 configuration **************************************/ DMA_InitStructure.DMA_Channel = DMA_Channel_0; DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address; //外设地址 DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue; //内存地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; //dma传输方向单向 DMA_InitStructure.DMA_BufferSize = 2; //设置DMA在传输时缓冲区的长度 word DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //设置DMA的外设递增模式,一个外设 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //设置DMA的内存递增模式, DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外设数据字长 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //内存数据字长 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //设置DMA的传输模式:连续不断的循环模式 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //设置DMA的优先级别 DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA2_Stream0, &DMA_InitStructure); DMA_Cmd(DMA2_Stream0, ENABLE); /* Configure ADC1 Channel6 pin as analog input ******************************/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; GPIO_Init(GPIOA, &GPIO_InitStructure); /* ADC Common Init **********************************************************/ ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式 ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4; //ADC时钟为APB2的4分频->84/4=21MHZ(F407ADC在2.4-3.6V供电电压下最大速率36M,稳定速度为30M) ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; ADC_CommonInit(&ADC_CommonInitStructure); /* ADC1 Init ****************************************************************/ ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//精度为12位 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //扫描方式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换 ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; //转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐 ADC_InitStructure.ADC_NbrOfConversion = 2; //规定了顺序进行规则转换的ADC通道的数目 ADC_Init(ADC1, &ADC_InitStructure); /* ADC1 regular channe6 configuration *************************************/ ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 1, ADC_SampleTime_3Cycles); //配置ADC1规则组(得出其单次采样时间为->(3+12)/21≈0.7us) ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 2, ADC_SampleTime_3Cycles); /* Enable DMA request after last transfer (Single-ADC mode) */ ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE); /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Start ADC1 Software Conversion */ ADC_SoftwareStartConv(ADC1);//软件启动转换 } 上面是我初始化ADC+DAM的代码。 下面我有3个问题。 问题1: 主函数中我是这样读取ADC值得 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ))//等待转换结束delay(1000); AD_value_1 = ADC_ConvertedValue[0]; AD_value_2 = ADC_ConvertedValue[1]; AD_value_1= (float)(AD_value_1/0xfff)*3.3; AD_value_2 = (float)(AD_value_2/0xfff)*3.3; 为什么我的程序老卡在 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC )) 这句上? 问题2:如何计算我的采样频率? 这点我不清楚,是2个通道每次采集用时0.7us还是每个通道都是0.7us. 还有就是,如何再提高下采集频率? 问题3:采集到的数据好多都是连着重复的,比如会有好多个0连着,还有好多2.632连着,数据根本不像正弦波。(我使用的是正弦波信号发生器,200KHZ,VPP=5V)。 |
6个回答
1、程序老卡在 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC )) 这句?
什么情况下发生的? 不要用单步验证这点。 2、根据你的配置每次每个通道的转换时间为0.7us. 提高ADC时钟和减少采样时间可以提高采样频率。 3、硬件正确的情况下,还需配置合适采样周期。 另外,ADC直接可转换的最高电压为3.6V.如果高了的话你得做前期处理。 |
huazhe 发表于 2018-11-9 14:45 如何提高ADC的时钟? ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4; 把4分频,变成ADC_Prescaler_Div2分频?除了这一点还能不能提高自身的ADC时钟? 配置合适采样周期 是不是满足采样定理就可以了? 我把ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 1, ADC_SampleTime_3Cycles); 里的 ADC_SampleTime_3Cycles改大些,是不是精度能提高? |
有人么?帮我解答下吧!!!
结贴,STM32F4的ADC采集1K的信号还行,但是频率大些的不适合。最后决定采用AD的ADC芯片。
学习一下 ADC+DMA
2404 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1259 浏览 0 评论
3258 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3034 浏览 4 评论
5571 浏览 0 评论
GMT+8, 2025-1-23 17:27 , Processed in 0.459240 second(s), Total 46, Slave 41 queries .
