首先,谢谢你的帮助。S29 GL512有一个以上的问题,我不能理解。1:低或高状态的We CE OE引脚在写作。2:在再次读取的情况下,1 STST引脚的状态。3:开始写和读例程,适当的CE CE OE引脚是足够的。0x055,0x0aAA在初始化例程中,如果没有足够的,我就缺少如何排序初始化代码。
以上来自于百度翻译 以下为原文 First of all thank you for your help. The S29GL512 has more than one problem I can not understand. 1: Low or High states of the WE CE OE pins in writing. 2: In the case of reading again the states of the 1 st posting pins. 3: To start the Write and Read routines, the appropriate CE CE OE pin is adequate. 0x0555, 0x0AAA in initialization routines if there is not enough I have a shortage of how to sort the initialization codes. |
你好,
你能提供你所用的全部号码吗?我们有S29 GL512S/T/P/N系列的并行NOR闪存。 E/CE/OE高/低状态请参考相应数据表的写入时序图片。 对于初始化代码,在我们的网站上有LLD为并行NOR Flash,您可以参考一些基本代码,下载链接在以下链接的“软件和工具”选项卡上: 并行NOR闪存 以上来自于百度翻译 以下为原文 Hi, Could you please provide the full part number you are using? We have S29GL512S/T/P/N series of parallel NOR flash. WE/CE/OE high/low state please reference the write timing picture from corresponding datasheet. For the initialization code, we have the LLD for parallel NOR flash on our website which there is some basic code you can reference, the download link is on the "Software & Tools" tab of the following link: Parallel NOR Flash Memory |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3672 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
575浏览 2评论
427浏览 2评论
439浏览 2评论
389浏览 2评论
921浏览 2评论
GMT+8, 2024-12-26 11:46 , Processed in 0.701099 second(s), Total 43, Slave 38 queries .
