你好,
我正在制作一个新的零件清单,我希望很快就能完成! 我查看了论坛,但我没有找到这个确切场景的问题,这可能会影响已经问过的问题的几个方面。 到目前为止,我对即将上映的PC的计划将有一个主启动M.2 SSD(这不需要加速)。 我打算在这个SSD上安装一些操作系统。 然后,我将为系统的Windows部分提供2个不同的硬盘驱动器作为辅助存储器,一个用于程序,一个用于游戏(这两个驱动器仅用于Windows)。 我不确定这是否会影响任何事情,但我会包含它以防万一,我可能会获得程序的SSHD并使用更大的HDD进行游戏,在这种情况下我不需要加速SSHD。 我还将为其他2个操作系统安装第三个硬盘驱动器(我不关心加速这个操作系统,因为操作系统与Optane不兼容)。 我是否有可能只使用Optane for Hard Drives 1和2(除非我得到SSHD然后我只需要加速其中的1个)(驱动器1和2只是Windows)或至少其中一个( 因为我不确定是否支持Multi-Drive加速)并让它们加速? 或者是双引导会使这变得不可能。 如果您希望我澄清一些事情,请告诉我。 此致 哈罗德 以上来自于谷歌翻译 以下为原文 Hello, I am currently working on making a new part list that I will hopefully get to complete soon! I have looked around the forums and I haven't found a question with this exact scenario which might affect a few aspects of the already asked questions. So far my plan for this upcoming PC will have a primary boot M.2 SSD (This will NOT need to be accelerated). I plan to install a few operating systems on this SSD. Then I will have 2 different Hard Drives as secondary storage for my Windows part of the system, one for programs and one for games (these 2 drives will be Windows only). I'm not sure if this will affect anything but I'll include it just in case, I might get an SSHD for the programs and use a larger HDD for games, in this case I would not need to accelerate the SSHD. I will also install a third hard drive for the other 2 operating systems (I do not care to accelerate this one as the operating systems would not be compatible with Optane). Is it possible for me to only use the Optane for Hard Drives 1 and 2 (Unless I get an SSHD then I will only need to accelerate 1 of them) (Drives 1 and 2 would be Windows Only) Or at least one of them (As I am not sure if there is support for Multi-Drive acceleration) and have them be accelerated? Or is dualbooting going to make this impossible. Also please let me know if you would like me to clarify something . Sincerely, Harold |
您好HaroldC,感谢您联系英特尔威廉希尔官方网站
支持。要回答您的问题,请查看“英特尔®Optane™内存常见问题”和“有关英特尔®Optane™安装和配置的常见问题解答”中包含的信息
记忆“下面:1。 用于系统加速的英特尔®Optane™内存系列的软件和硬件要求的完整列表是什么?您正在加速的SATA启动驱动器必须包含:•GPT分区•512B扇区格式•Windows®1064位操作系统 启动卷末尾至少有5 MB的连续未分配空间注意•系统加速不支持PCIe * NVMe *驱动器•仅使用软件版本16.0.2.1086或更高版本支持系统加速的辅助/数据驱动器。 有关详细信息,请参阅此处。•系统加速不支持具有多个操作系统的单个SATA驱动器。 我们不建议使用此功能,但我们不保证结果。 请参阅“用户和安装指南”中的完整要求。•双OS引导系统 - 具有多个存储驱动器的系统,每个系统包含一个操作系统 - 不受支持,并且无法保证结果。 我是否可以在包含多个卷的SATA驱动器上启用系统加速(例如,启动卷和数据卷)?支持包含一个启动分区/卷以及数据分区/卷的SATA驱动器的系统加速。 具有多个引导分区/卷的SATA驱动器不是受支持的配置或用例。 结果无法保证,我们不建议配置。 我打算在我的系统上跨多个驱动器使用多个操作系统。 英特尔®Optane™内存能否提升多个硬盘的性能?•不,英特尔®Optane™内存可以加速一个基于SATA的硬盘。我们希望您发现这些信息非常有用。最好的问候,Josh B.Intel客户支持威廉希尔官方网站 人员与英特尔的合同 公司 以上来自于谷歌翻译 以下为原文 Hello HaroldC, Thank you for contacting Intel Technical Support. To answer to your questions, please find the information included on the “Frequently Asked Questions for Intel® Optane™ Memory” and the “Frequently Asked Questions about Installation and Configuration for Intel® Optane™ Memory” below: 1. What is the complete list of software and hardware requirements for the Intel® Optane™ memory series for system acceleration? The SATA boot drive you're accelerating must contain: • GPT partition • 512B Sector format • Windows® 10 64-bit operating system with at least 5 MB of continuous unallocated space at the end of the boot volume Note • PCIe* NVMe* drives aren't supported for system acceleration • Secondary/Data drives are supported for system acceleration with software version 16.0.2.1086 or later only. For more information, see here. • A single SATA drive with multiple operating systems isn't supported with system acceleration. We don't recommend this use, and we don't guarantee results. See the full requirements in the User and Installation Guide. • Dual OS Boot systems--systems with more than one storage drive, each containing an OS--aren't supported and results can't be guaranteed. 2. Can I enable system acceleration on my SATA drive that contains more than one volume (for example, a boot volume and a data volume)? System acceleration of a SATA drive that contains one boot partition/volume and also data partitions/volumes is supported. A SATA drive with multiple boot partitions/volumes isn't a supported configuration or use case. Results can't be guaranteed and we don't recommend the configuration. 3. I intend to have multiple operating systems on my system across multiple drives. Can Intel® Optane™ memory boost the performance of multiple drives? • No, Intel® Optane™ memory can accelerate one SATA-based drive. We hope you find this information useful. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-11-9 14:50 您好HaroldC。感谢您联系了英特尔威廉希尔官方网站 支持。 自上次沟通以来,我们没有收到您的回复,我们想知道您是否需要进一步的帮助,或者我们是否可以结案;重要提示:如果需要进一步的帮助或澄清,如果您回复此帖子,我们将不胜感激。 除非你的询问完全不相关,否则不要写新的。 这样我们就可以防止产生重复的帖子,我们也不会失去思路。我们期待着您的回复。最好的问候,Josh B.Intel客户支持。 以上来自于谷歌翻译 以下为原文 Hello HaroldC. Thank you for having contacted Intel Technical Support. We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case? Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought. We will be looking forward to your reply. Best regards, Josh B. Intel Customer Support. |
449浏览 0评论
GMT+8, 2024-11-10 23:46 , Processed in 0.442104 second(s), Total 47, Slave 42 queries .
