在用STM32F429驱动SDRAM时,初始化代码用cubeMX生成,代码如下: DRAM_HandleTypeDef hsdram1; /* FMC initialization function */ void MX_FMC_Init(void) { FMC_SDRAM_TimingTypeDef SdramTiming; /** Perform the SDRAM1 memory initialization sequence */ hsdram1.Instance = FMC_SDRAM_DEVICE; /* hsdram1.Init */ hsdram1.Init.SDBank = FMC_SDRAM_BANK1; hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9; hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_12; hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16; hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4; hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3; hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE; hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2; hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE; hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1; /* SdramTiming */ SdramTiming.LoadToActiveDelay = 2; SdramTiming.ExitSelfRefreshDelay = 7; SdramTiming.SelfRefreshTime = 4; SdramTiming.RowCycleDelay = 7; SdramTiming.WriteRecoveryTime = 2; SdramTiming.RPDelay = 2; SdramTiming.RCDDelay = 2; if(HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK) { /* Initialization Error */ #ifdef DEBUG printf("SDRAM Initialization Errorn"); #endif } } static int FMC_Initialized = 0; static void HAL_FMC_MspInit(void){ /* USER CODE BEGIN FMC_MspInit 0 */ /* USER CODE END FMC_MspInit 0 */ GPIO_InitTypeDef GPIO_InitStruct; if (FMC_Initialized) { return; } FMC_Initialized = 1; /* Peripheral clock enable */ __HAL_RCC_FMC_CLK_ENABLE(); /** FMC GPIO Configuration PF0 ------> FMC_A0 PF1 ------> FMC_A1 PF2 ------> FMC_A2 PF3 ------> FMC_A3 PF4 ------> FMC_A4 PF5 ------> FMC_A5 PC0 ------> FMC_SDNWE PC2 ------> FMC_SDNE0 PC3 ------> FMC_SDCKE0 PF11 ------> FMC_SDNRAS PF12 ------> FMC_A6 PF13 ------> FMC_A7 PF14 ------> FMC_A8 PF15 ------> FMC_A9 PG0 ------> FMC_A10 PG1 ------> FMC_A11 PE7 ------> FMC_D4 PE8 ------> FMC_D5 PE9 ------> FMC_D6 PE10 ------> FMC_D7 PE11 ------> FMC_D8 PE12 ------> FMC_D9 PE13 ------> FMC_D10 PE14 ------> FMC_D11 PE15 ------> FMC_D12 PD8 ------> FMC_D13 PD9 ------> FMC_D14 PD10 ------> FMC_D15 PD14 ------> FMC_D0 PD15 ------> FMC_D1 PG4 ------> FMC_BA0 PG5 ------> FMC_BA1 PG8 ------> FMC_SDCLK PD0 ------> FMC_D2 PD1 ------> FMC_D3 PG15 ------> FMC_SDNCAS PE0 ------> FMC_NBL0 PE1 ------> FMC_NBL1 */ /* GPIO_InitStruct */ GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_11|GPIO_PIN_12 |GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_FMC; HAL_GPIO_Init(GPIOF, &GPIO_InitStruct); /* GPIO_InitStruct */ GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_FMC; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* GPIO_InitStruct */ GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5 |GPIO_PIN_8|GPIO_PIN_15; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_FMC; HAL_GPIO_Init(GPIOG, &GPIO_InitStruct); /* GPIO_InitStruct */ GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10 |GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14 |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_FMC; HAL_GPIO_Init(GPIOE, &GPIO_InitStruct); /* GPIO_InitStruct */ GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14 |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_FMC; HAL_GPIO_Init(GPIOD, &GPIO_InitStruct); /* USER CODE BEGIN FMC_MspInit 1 */ /* USER CODE END FMC_MspInit 1 */ } void HAL_SDRAM_MspInit(SDRAM_HandleTypeDef* hsdram){ /* USER CODE BEGIN SDRAM_MspInit 0 */ /* USER CODE END SDRAM_MspInit 0 */ HAL_FMC_MspInit(); /* USER CODE BEGIN SDRAM_MspInit 1 */ /* USER CODE END SDRAM_MspInit 1 */ } static int FMC_DeInitialized = 0; static void HAL_FMC_MspDeInit(void){ /* USER CODE BEGIN FMC_MspDeInit 0 */ /* USER CODE END FMC_MspDeInit 0 */ if (FMC_DeInitialized) { return; } FMC_DeInitialized = 1; /* Peripheral clock enable */ __HAL_RCC_FMC_CLK_DISABLE(); /** FMC GPIO Configuration PF0 ------> FMC_A0 PF1 ------> FMC_A1 PF2 ------> FMC_A2 PF3 ------> FMC_A3 PF4 ------> FMC_A4 PF5 ------> FMC_A5 PC0 ------> FMC_SDNWE PC2 ------> FMC_SDNE0 PC3 ------> FMC_SDCKE0 PF11 ------> FMC_SDNRAS PF12 ------> FMC_A6 PF13 ------> FMC_A7 PF14 ------> FMC_A8 PF15 ------> FMC_A9 PG0 ------> FMC_A10 PG1 ------> FMC_A11 PE7 ------> FMC_D4 PE8 ------> FMC_D5 PE9 ------> FMC_D6 PE10 ------> FMC_D7 PE11 ------> FMC_D8 PE12 ------> FMC_D9 PE13 ------> FMC_D10 PE14 ------> FMC_D11 PE15 ------> FMC_D12 PD8 ------> FMC_D13 PD9 ------> FMC_D14 PD10 ------> FMC_D15 PD14 ------> FMC_D0 PD15 ------> FMC_D1 PG4 ------> FMC_BA0 PG5 ------> FMC_BA1 PG8 ------> FMC_SDCLK PD0 ------> FMC_D2 PD1 ------> FMC_D3 PG15 ------> FMC_SDNCAS PE0 ------> FMC_NBL0 PE1 ------> FMC_NBL1 */ HAL_GPIO_DeInit(GPIOF, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3 |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_11|GPIO_PIN_12 |GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15); HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3); HAL_GPIO_DeInit(GPIOG, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5 |GPIO_PIN_8|GPIO_PIN_15); HAL_GPIO_DeInit(GPIOE, GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10 |GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14 |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1); HAL_GPIO_DeInit(GPIOD, GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_14 |GPIO_PIN_15|GPIO_PIN_0|GPIO_PIN_1); /* USER CODE BEGIN FMC_MspDeInit 1 */ /* USER CODE END FMC_MspDeInit 1 */ } void HAL_SDRAM_MspDeInit(SDRAM_HandleTypeDef* hsdram){ /* USER CODE BEGIN SDRAM_MspDeInit 0 */ /* USER CODE END SDRAM_MspDeInit 0 */ HAL_FMC_MspDeInit(); /* USER CODE BEGIN SDRAM_MspDeInit 1 */ /* USER CODE END SDRAM_MspDeInit 1 */ } /** * @} */ /** * @} */ /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/ 配置代码如下: static void SDRAM_Initialization_Sequence(SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_CommandTypeDef *Command) { __IO uint32_t tmpmrd =0; /* Step 3: Configure a clock configuration enable command */ /* ʱÖÓÅäÖÃʹÄÜ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè3 */ Command->CommandMode = FMC_SDRAM_CMD_CLK_ENABLE; Command->CommandTarget = FMC_SDRAM_CMD_TARGET_BANK1; Command->AutoRefreshNumber = 1; Command->ModeRegisterDefinition = 0; /* Send the command */ HAL_SDRAM_SendCommand(hsdram,Command, 0x1000); /* Step 4: Insert 100 ms delay */ /* µÈ´ýÖ¸¶¨ÑÓ³ÙÖÜÆÚ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè4 */ HAL_Delay(100); /* Step 5: Configure a PALL (precharge all) command */ /* PALL£¨¡°Ô¤³äµçËùÓд洢ÇøÓò¡±£©ÃüÁî,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè5 */ Command->CommandMode = FMC_SDRAM_CMD_PALL; Command->CommandTarget = FMC_SDRAM_CMD_TARGET_BANK1; Command->AutoRefreshNumber = 1; Command->ModeRegisterDefinition = 0; /* Send the command */ HAL_SDRAM_SendCommand(hsdram,Command, 0x1000); /* Step 6 : Configure a Auto-Refresh command */ /* ×ÔË¢ÐÂÃüÁî,8¸ö×ÔË¢ÐÂÖÜÆÚ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè6 */ Command->CommandMode = FMC_SDRAM_CMD_AUTOREFRESH_MODE; Command->CommandTarget = FMC_SDRAM_CMD_TARGET_BANK1; Command->AutoRefreshNumber = 9; Command->ModeRegisterDefinition = 0; /* Send the command */ HAL_SDRAM_SendCommand(hsdram,Command, 0x1000); /* Step 7: Program the external memory mode register */ /* ÅäÖÃSDRAMģʽ¼Ä´æÆ÷,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè7 */ /* Í»·¢³¤¶È£º1 Í»·¢´«Ê䷽ʽ£ºË³Ðò CASDZ·üÆÚ£º2 ²Ù×÷ģʽ£º±ê×¼ ²Ù×÷ģʽ£ºÍ»·¢¶Á/µ¥Ò»Ð´ */ tmpmrd = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_1 | SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL | SDRAM_MODEREG_CAS_LATENCY_2 | SDRAM_MODEREG_OPERATING_MODE_STANDARD | SDRAM_MODEREG_WRITEBURST_MODE_SINGLE; Command->CommandMode = FMC_SDRAM_CMD_LOAD_MODE; Command->CommandTarget = FMC_SDRAM_CMD_TARGET_BANK1; Command->AutoRefreshNumber = 1; Command->ModeRegisterDefinition = tmpmrd; /* Send the command */ HAL_SDRAM_SendCommand(hsdram,Command, 0x1000); /* Step 8: Set the refresh rate counter */ /* Ë¢ÐÂÂÊÉèÖÃ,¶ÔÓ¦STM32³õʼ»¯SDRAM²½Öè8 */ /* (15.62 us x Freq) - 20 */ /* Set the device refresh counter */ HAL_SDRAM_ProgramRefreshRate(hsdram, REFRESH_COUNT); } 硬件部分已经检查了很多遍,没有连接错误,没有假焊/短路,但是SDRAM就是读写错误,用示波器测试一下,发现SDCLK没有信号输出.测量没有发现短路和开路.把SDRAM更换了也一样.请各位高手帮忙看看是否代码有问题,谢谢!!!!!!! |
5个回答
看一下硬件上的资源选择是否正确,我测试407的。用的NE3操作SRAM是没有问题的。
你确认SDRAM时钟使能了。
看你代码里有 __HAL_RCC_FMC_CLK_ENABLE(); 和 __HAL_RCC_FMC_CLK_DISABLE(); 你确认下到底最后哪个在起作用。 |
应该是你FMC时钟没开启
确认FMC的时钟已经使能,在DEBUG下查看相关控制寄存器的数值都是对的,其它数据线/地址线引脚上都有信号输出,就是SDCLK和SDCKE上没有输出信号,SDRAM和STM32F429的芯片都更换过了,结果还是一样
我也遇到同样问题,读写的时候,地址,数据都有波形,clk,nwe等等都是没有信号,没有找到原因 我是用stm32cube 生成的代码,不知道哪里出错 /* FMC initialization function */ static void MX_FMC_Init(void) { FMC_SDRAM_TimingTypeDef SdramTiming; /** Perform the SDRAM1 memory initialization sequence */ hsdram1.Instance = FMC_SDRAM_DEVICE; /* hsdram1.Init */ hsdram1.Init.SDBank = FMC_SDRAM_BANK1; hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9; hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13; hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16; hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4; hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_2; hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE; hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2; hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_DISABLE; hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_0; /* SdramTiming */ SdramTiming.LoadToActiveDelay = 3; SdramTiming.ExitSelfRefreshDelay = 12; SdramTiming.SelfRefreshTime = 3; SdramTiming.RowCycleDelay = 8; SdramTiming.WriteRecoveryTime = 2; SdramTiming.RPDelay = 3; SdramTiming.RCDDelay = 3; if (HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK) { Error_Handler(); } } |
STM32串口接受中断使用C++STL中的queue导致所有中断失效
6379 浏览 1 评论
3085 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1333 浏览 0 评论
3917 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3758 浏览 4 评论
GMT+8, 2025-2-13 15:31 , Processed in 0.432735 second(s), Total 48, Slave 43 queries .
