我设计了一个触摸按钮的PCB,我怎么知道按钮被触摸了,如果我想要长的触摸键和短的触摸键,我该怎么办?
以上来自于百度翻译 以下为原文 i design a pcb of touch button, how do i know the button was touched, and if i want long touch key and short touch key , what should i do ? |
嗨,戴维,
如果您使用的是CAPENSESEYCSDV2.X,可以使用CAPENSESEYSCONSORMONDATION[],这是一个Unt8阵列,它可以保持传感器“或”关闭状态(用于按钮、矩阵按钮或滑块)。CabSnSeSysRealon掩膜[ 0 ]包含用于传感器0到7的屏蔽位(传感器0是位0,SCONSOR1是位1)。CabSnSeSysRealon掩膜(1)包含传感器8到15(如果需要的话)的掩蔽位,等等。这个UIT8阵列包含尽可能多的元素,以容纳所有放置的传感器。如果传感器处于开启状态,则位的值为1,如果传感器关闭,则为0。 如果您使用的是CAPENSESEYCSDv3.x/ 4 .x/x.x.x,可以使用Strut实例:CAPENSESEYDSRAM。它的原型是在CabSnSexRM结构中定义的。 无论是长触摸还是短触摸,都需要定制代码来识别它。 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi David, If you are using CapSense_CSD v2.x, you can use CapSense_sensorOnMask[], This is a uint8 array that holds the sensor 'on' or 'off' state (for buttons, matrix buttons or sliders). CapSense_sensorOnMask[0] contains the masked bits for sensor 0 through 7 (sensor 0 is bit 0, sensor1 is bit 1). CapSense_sensorOnMask[1] contains the masked bits for sensor 8 through 15 (if they are needed), and so on. This uint8 array contains as many elements as are necessary to contain all placed sensor. The value of a bit is 1 if the sensor is on and 0 if the sensor is off. If you are using CapSense_CSD v3.x/4.x/5.x, you can use the struct instance: CapSense_dsRam.snsStatus[wdgtId]. Its prototype is defined in CapSense_RAM_STRUCT in CapSense_Structure.h. Either long touch or short touch, requires customized code to identify it. Thanks, Ryan |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-25 00:08 , Processed in 0.872563 second(s), Total 75, Slave 59 queries .
