嗨,
如果pblock_a中有一些BRAM,但是没有使用它们,那么其他模块可以使用这些BRAM吗? 谢谢, 以上来自于谷歌翻译 以下为原文 Hi, If there are some BRAMs in pblock_a, but they are not used, so other modules can use these BRAMs? Thanks, |
@ araongao2015
是的,除非您的pblock设置了EXCLUDE_PLACEMENT属性。 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 pblock默认禁用此属性。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @araongao2015 Yes, unless your pblock has EXCLUDE_PLACEMENT property set on it. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 This property is disabled by default for pblock. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
@ araongao2015
是的,除非您的pblock设置了EXCLUDE_PLACEMENT属性。 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 pblock默认禁用此属性。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @araongao2015 Yes, unless your pblock has EXCLUDE_PLACEMENT property set on it. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 This property is disabled by default for pblock. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
2508 浏览 7 评论
2878 浏览 4 评论
2334 浏览 9 评论
3428 浏览 0 评论
2514 浏览 15 评论
2595浏览 1评论
668浏览 1评论
532浏览 1评论
818浏览 0评论
GMT+8, 2025-3-4 18:20 , Processed in 1.349122 second(s), Total 79, Slave 63 queries .
