NUC7CJYH2,Bios 44
Onkyo HT-S5805 LG 55UH6159 当我将NUC直接与电视连接时,一切似乎都很好。 当我在中间连接Onkyo时,没有图片,甚至没有启动画面。 当我使用我的笔记本时,我得到一个很好的照片。 我读到了不同NUC和不同Onkyos的相同问题,看起来没有任何改变。 所以 - 如果有一个Onkyo,这个NUC是否一文不值? 以上来自于谷歌翻译 以下为原文 NUC7CJYH2, Bios 44 Onkyo HT-S5805 LG 55UH6159 When I connect the NUC directly with the TV all seems fine. When I connect the Onkyo in the middle there is no picture, even no boot screen. When I use my notebook instead I get a nice pic. I read about same issues with different NUCs and different Onkyos and it looks like there has nothing changed. So - is this NUC worthless if one got an Onkyo? |
8个回答
“那么 - 如果有人得到一个Onkyo,这个NUC是否毫无价值吗?”
那个,或者Onkyo毫无价值。 文件 以上来自于谷歌翻译 以下为原文 "So - is this NUC worthless if one got an Onkyo?" That, or the Onkyo is worthless. Doc |
我没有提到它,但我希望有更多以解决方案为重点的答案...... 以上来自于谷歌翻译 以下为原文 I did not mention it, but I was hoping for more solution-focused answers .... |
我家里有两个Onkyo接收器,一个较旧的TX-NR616和一个全新的4K支持TX-NR575。 我有NUC连接到两个接收器,并没有任何问题。 事实上,我已经使用这款新接收器测试了多个NUC型号而没有问题(给出或采取我正在使用的三星6系列电视的一些特定问题)。 我可以做的最重要的建议是确保您使用质量好,符合HDMI 2.0b标准的电缆。 大多数带有组件的电缆都是绝对垃圾,如果可以,应该避免使用它们。 希望这可以帮助, 内容S 附: 哎呀,大多数人都喜欢Al的幽默尝试(强调“尝试”)...... 以上来自于谷歌翻译 以下为原文 I have two Onkyo receivers in the house, an older TX-NR616 and a brand new, 4K supporting, TX-NR575. I have NUCs connected to both receivers and have no problems with them at all. In fact, I have tested multiple NUC models with this new receiver without issue (give or take a few issues specific to the Samsung 6 Series TV that I am using). The most important suggestion I can make is to ensure that you use good quality, HDMI 2.0b-compliant cables. Most cables that come with components are absolute trash and you should avoid them if you can. Hope this helps, ...S P.S. Gee, most people enjoy Al's attempts at humor (emphasis on 'attempts')... |
tianyou15 发表于 2018-11-8 11:22 谢谢你的建议。 我会考虑,如果设置不能使用与电视,UHD和60Hz的直接模式相同的电缆。 但确实...... 以上来自于谷歌翻译 以下为原文 Thanks for that advise. I would consider that, if the setting would'nt work with the same cables in direct mod with the TV, UHD and 60Hz. But it does ... |
啊,你在这里应用逻辑。 不要那么做! 以上来自于谷歌翻译 以下为原文 Ah, you are applying logic here. Stop that! |
是的,你确实在哪里。 我购买了经过认证的HDMI-2.0b电缆,用于NUC和接收器之间的连接,现在可以使用了。 谢谢! 以上来自于谷歌翻译 以下为原文 Yeah, you where right indeed. I bought a certified HDMI-2.0b-cable for the connection between NUC and receiver and now it works. Thanks! |
是。 不符合逻辑 - 但是布丁的证据就在于此! 内容S 以上来自于谷歌翻译 以下为原文 Yes. Not logical - but proof is in the pudding! ...S |
有时,在不久的将来,所有电缆都将同样创建。 这样,要么一切都会奏效,否则什么都行不通。 文件 以上来自于谷歌翻译 以下为原文 Sometime, in the not too distant future, all cables will be created equally. That way, either everything will work, or nothing will work. Doc |
GMT+8, 2025-2-24 17:21 , Processed in 0.549434 second(s), Total 55, Slave 50 queries .
