嗨,
我正在使用LSM6DSL并且无法在加速度计上操作X轴。 Y轴和Z轴给出了正确的结果,但X轴稳定在32756并且仅变化5个点。我有4台LSM6DSL设备,所有设备都一样。即使没有FIFO测试(相同的结果)。因为4个设备做同样的事情,我不确定设备是否有故障。 这是我的设置: / *在多字节期间启用寄存器地址自动递增 使用串行接口访问。 * / LSM6DSL_ACC_GYRO_W_IF_Addr_Incr(NULL,LSM6DSL_ACC_GYRO_IF_INC_ENABLED); / *启用BDU * / LSM6DSL_ACC_GYRO_W_BDU(NULL,LSM6DSL_ACC_GYRO_BDU_BLOCK_UPDATE); //低功耗使能(XL_HM_MODE = 1) LSM6DSL_ACC_GYRO_W_LowPower_XL(NULL,LSM6DSL_ACC_GYRO_LP_XL_DISABLED); / *比例选择。 * / LSM6DSL_ACC_GYRO_W_FS_XL(NULL,LSM6DSL_ACC_GYRO_FS_XL_4g); / *设置加速FIFO抽取* / LSM6DSL_ACC_GYRO_W_DEC_FIFO_XL(NULL,LSM6DSL_ACC_GYRO_DEC_FIFO_XL_NO_DECIMAtiON); / *将FIFO ODR设置为最高值* / LSM6DSL_ACC_GYRO_W_ODR_FIFO(NULL,LSM6DSL_ACC_GYRO_ODR_FIFO_6600Hz); / *在INT2上设置FIFO_FULL * / LSM6DSL_ACC_GYRO_W_FULL_FLAG_on_INT2(NULL,LSM6DSL_ACC_GYRO_INT2_FULL_FLAG_ENABLED); / *设置FIFO水印* / LSM6DSL_ACC_GYRO_W_FIFO_Watermark(NULL,FIFO_WATERMARK); / *将FIFO深度设置为限制为水印阈值级别* / if(LSM6DSL_ACC_GYRO_W_STOP_ON_FTH(NULL,LSM6DSL_ACC_GYRO_STOP_ON_FTH_ENABLED); / *将ODR设置为104Hz * / LSM6DSL_ACC_GYRO_W_ODR_XL(NULL,LSM6DSL_ACC_GYRO_ODR_XL_104Hz); / *将FIFO模式设置为连续* / LSM6DSL_ACC_GYRO_W_FIFO_MODE(NULL,LSM6DSL_ACC_GYRO_FIFO_MODE_DYN_STREAM_2);谢谢 Ondrej Meca #lsm6dsl 以上来自于谷歌翻译 以下为原文 Hi, I'm using LSM6DSL and unable to operate X axis on accelerometer. The Y and Z axes give me the right results but X axis is stable at 32756 and changes only by 5 points. I have 4 devices with LSM6DSL and all behave same. Tested even without FIFO (same result). Because 4 devices do the same, I'm not sure of device fault. Here is my setup: /* Enable register address automatically incremented during a multiple byte access with a serial interface. */ LSM6DSL_ACC_GYRO_W_IF_Addr_Incr(NULL, LSM6DSL_ACC_GYRO_IF_INC_ENABLED); /* Enable BDU */ LSM6DSL_ACC_GYRO_W_BDU(NULL, LSM6DSL_ACC_GYRO_BDU_BLOCK_UPDATE );// Low power enabled (XL_HM_MODE = 1) LSM6DSL_ACC_GYRO_W_LowPower_XL(NULL, LSM6DSL_ACC_GYRO_LP_XL_DISABLED) ;/* Scale selection. */ LSM6DSL_ACC_GYRO_W_FS_XL(NULL, LSM6DSL_ACC_GYRO_FS_XL_4g );/* Set accelero FIFO decimation */ LSM6DSL_ACC_GYRO_W_DEC_FIFO_XL(NULL, LSM6DSL_ACC_GYRO_DEC_FIFO_XL_NO_DECIMATION); /* Set FIFO ODR to highest value */ LSM6DSL_ACC_GYRO_W_ODR_FIFO(NULL, LSM6DSL_ACC_GYRO_ODR_FIFO_6600Hz);/* Set FIFO_FULL on INT2 */ LSM6DSL_ACC_GYRO_W_FULL_FLAG_on_INT2(NULL, LSM6DSL_ACC_GYRO_INT2_FULL_FLAG_ENABLED); /* Set FIFO watermark */ LSM6DSL_ACC_GYRO_W_FIFO_Watermark(NULL, FIFO_WATERMARK); /* Set FIFO depth to be limited to watermark threshold level */ if(LSM6DSL_ACC_GYRO_W_STOP_ON_FTH(NULL, LSM6DSL_ACC_GYRO_STOP_ON_FTH_ENABLED);/* Set ODR at 104Hz */ LSM6DSL_ACC_GYRO_W_ODR_XL(NULL, LSM6DSL_ACC_GYRO_ODR_XL_104Hz);/* Set FIFO mode to Continuous */ LSM6DSL_ACC_GYRO_W_FIFO_MODE(NULL, LSM6DSL_ACC_GYRO_FIFO_MODE_DYN_STREAM_2);Thanks Ondrej Meca #lsm6dsl |
嘿,
你也可以发表你的阅读计划吗?这可能对那些想要帮助您调试的人有所帮助 以上来自于谷歌翻译 以下为原文 Hey, Could you also post your reading scheme ? This might be of help to those who would like to help you debug |
2877 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3710 浏览 6 评论
6124 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 01:53 , Processed in 1.163023 second(s), Total 74, Slave 58 queries .
