嗨,我想知道在Keysight VNA上使用不同类型的供应商电缆是否有任何问题。
我知道是德科技推荐使用特定VNA的特定电缆,但除了频率之外。 限制在不使用特定VNA的推荐电缆时可能遇到的主要问题。 您也可以使用更高频率的其他Keysight电缆。 频率较低的单位。 是德科技VNA。 我有两条2.92mm VNA级电缆(不是Keysight)..谢谢。 以上来自于谷歌翻译 以下为原文 hi, I want to know if there are any issues in using different type of vendors cables on Keysight VNAs. I know Keysight recommend using specific cables for specific VNAs, but aside freq. limits what are the major problems one can have when not using the recommended cables for a specific VNA. Also can you use other Keysight cables from higher freq. units with lower Freq. Keysight VNAs. I do have two 2.92mm VNA grade cables (not Keysight).. Thanks. |
唯一的问题是2.92连接器(特别是母头)不是特别坚固且容易损坏。
如果您的2.92 F电缆连接到3.5mm M测试端口,它将起作用但测量不稳定。 以上来自于谷歌翻译 以下为原文 The only issue is really that the 2.92 connectors (especially female) are not paraticularly robust and are easily damaged. If you have a damaged 2.92 F cable connected to the 3.5mm M test port, it will work but give unstable measurements. |
根据这些图片,这些电缆似乎缺少适当的连接器端。 换句话说,缺少部件。 2.92连接器应与3.5 mm连接器类似,并带有较厚的接地平面壁。 精密连接器将在中心销周围具有空气电介质,而不是像SMA连接器那样的聚丙烯。 螺母和母连接器的物理尺寸和螺纹与SMA相同。 基本上回答你关于电缆的问题。 是德科技推荐的VNA电缆具有某些对质量测量很重要的特性。 它们是优质的连接器端,低VSWR性能,幅度和相位稳定。 不正确的测试端口电缆已被证明是VNA测量不当的两大原因之一。 问候,戴夫 以上来自于谷歌翻译 以下为原文 Based on those pictures, those are cables that appear to be missing their appropriate connector ends. In other words, parts are missing. The 2.92 connector should appear similar to a 3.5 mm connector with with a thicker ground plane wall. The precision connectors will have a air dielectric around the center pin, not poly-propolene like a SMA connector. The physical size and threads of the nut and female connector are the same as SMA. To basically answer your question on cables. The VNA cables recommended by Keysight have certain characteristics that are important for quality measurements. They are quality connector ends, low VSWR performance, amplitude and phase stable. The incorrect test port cables have shown to be one of the top two causes of improper measurements from a VNA. Regards, Dave |
1609 浏览 0 评论
2560 浏览 1 评论
2433 浏览 1 评论
2275 浏览 5 评论
3211 浏览 3 评论
1019浏览 0评论
1609浏览 0评论
GMT+8, 2025-7-15 05:23 , Processed in 1.707723 second(s), Total 47, Slave 41 queries .
