你好,
关于英特尔的Quartus II,Quartus Prime,JTAG编程,你有S29 GL064的经验吗? 在我发现的材料中,S29 GL—S系列仅支持超过128兆比特的模型数。 为什么S29 G064不支持它? http://www. Altera.com /内容/BAD/Altera WWW/Global/EnUsU/PDFS/DeP/UG/UGYPFL。 当做, 森本 以上来自于百度翻译 以下为原文 Hi, About the Quartus II, Quartus Prime of Intel on JTAG programming, Do you have experience with S29GL064? In the material I found, the S29GL-S series only supports model numbers over 128 Mbit. Is there a reason why S29G064S does not support it? https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/ug_pfl.pdf#page=5 Regards, Naoaki Morimoto |
你好,
我们没有与Altera FPGA S29 GL064的经验,但由于S29 GL064 S与其他CFI闪存设备兼容,所以应该得到支持。 GL064的原因不在于你所观察到的材料,可能是因为该设备比其他GL-S系列设备更新。 用户应该把GL064作为任何其他CFI闪存,它应该工作。 谢谢, 纳达 以上来自于百度翻译 以下为原文 Hi, We don’t have experiences with S29GL064S with Altera FPGA, but since S29GL064S is compatible with other CFI Flash devices, it should be supported. The reason GL064S was not in the materials you are looking at is likely because the device is newer than other GL-S family devices. User should just treat GL064S as any other CFI flash and it should work. Thanks, Nada |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3672 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
574浏览 2评论
426浏览 2评论
439浏览 2评论
389浏览 2评论
920浏览 2评论
GMT+8, 2024-12-26 04:52 , Processed in 0.753188 second(s), Total 76, Slave 60 queries .
