什么是“HM87 LPC控制器”,它有什么作用?
我刚刚用驱动程序更新程序更新了它,我真的不知道我做了什么。 以上来自于谷歌翻译 以下为原文 What is the "HM87 LPC Controller" and what does it do? I just updated it with a driver update program and I really don't know what I did. |
希望您没有使用网络上的第三方驱动程序更新程序。
文件 以上来自于谷歌翻译 以下为原文 Hopefully, you did not use a third party driver update program found on the web. Doc |
首先,HM87是您的8系列移动芯片组,它支持您的第4代移动英特尔处理器。 LPC(低引脚数)总线是一种传统总线,用于连接超级I / O IC,TPM等设备。该总线的控制器位于芯片组中(位于平台控制器中枢(PCH)IC中) 包含这个芯片组)。 您所做的是更新支持此LPC总线控制器的驱动程序的配置。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 First of all, the HM87 is your 8-Series Mobile chipset and it supports your 4th generation Mobile Intel processor. The LPC (Low Pin Count) bus is a legacy bus that is used to connect devices such as Super I/O ICs, TPMs, etc. The controller for this bus is located in the chipset (in the Platform Controller Hub (PCH) IC that comprises this chipset). What you have done is update the configuration of the driver that supports this LPC bus controller. Hope this helps, ...S |
573浏览 0评论
GMT+8, 2025-2-12 09:35 , Processed in 0.396985 second(s), Total 49, Slave 43 queries .
