我注意到我的NUC上有几个问题可能没什么,但是看起来很奇怪:
1.当我按下NUC上的电源按钮和显示器显示初始引导屏幕(以及USB外围设备通电)之间有大约8-10的延迟。 2.初始启动屏幕显示“Intel NUC”和显示屏右上角的几个方块,标签为“Setup”和“BBS”,但就是这样。 没有说明“按F2进入BIOS”或类似的说明 - 除了“Intel NUC”,“Setup”和“BBS”文本之外,屏幕是空白的 以上问题是否正常? NUC完全可以运行,因此这些问题似乎无害,但看起来很奇怪,启动屏幕不会给用户提供有关如何进入BIOS的指导,并且显示器初始化之间的长时间断电似乎过多 与我用过的其他主板相比。 谢谢! - 罗伯特· 以上来自于谷歌翻译 以下为原文 I've noticed a couple of issues on my NUC that may be nothing, but seem strange nonetheless: 1. There is a roughly 8-10 delay between when I press the power button on the NUC and when the display shows the initial boot screen (and USB peripherals get powered up). 2. The initial boot screen shows "Intel NUC" and a couple of squares in the upper right hand corner of the display with the labels "Setup" and "BBS", but that's it. There are no instructions that say "Press F2 to enter BIOS" or anything like that - the screen is blank other than the "Intel NUC", "Setup", and "BBS" text Are the above issues normal? The NUC is otherwise fully operational, and so the issues seem hARMless, but it seems strange that the boot screen wouldn't give the user some guidance about how to get in to the BIOS, and the long power on delay between display initialization seems excessive compared to other motherboards I have used. Thanks! -Robert |
3个回答
是的,这正是我的工作方式。
你使用什么样的启动驱动器,并根据你的答案,可能是启动延迟的来源。 麦克风 以上来自于谷歌翻译 以下为原文 Yes, that exactly how mine works. What kind of boot drive are you using, and depending on your answer, may be the source of boot delays. Mike |
1.延迟8到10秒,直到您看到英特尔徽标正常。
2.如果要在引导期间看到F2,F7,F10菜单,则需要在Bios中禁用安全引导。 它在Bios默认设置中设置为On。 要输入Bios设置,请从电源按钮菜单中按F2。 您可以从Windows高级菜单输入Bios。 莱昂 以上来自于谷歌翻译 以下为原文 1. 8 to 10 seconds delay till you see the Intel logo is normal. 2. If you want to see the F2, F7, F10 menu during boot, you need to disable Secure Boot in Bios. It is set to On in Bios default settings. To enter Bios settings, press F2 from Power Button Menu. You may enter Bios from Windows Advanced Menu. Leon |
飞雪9366 发表于 2018-11-7 12:53 迈克,莱昂, 谢谢你们的回复! 很高兴知道我的NUC上的启动行为是正常的...... - 罗伯特· 以上来自于谷歌翻译 以下为原文 Mike, Leon, Thank you both for your replies! It's good to know the boot behavior on my NUC is normal... -Robert |
538浏览 0评论
GMT+8, 2025-1-13 04:55 , Processed in 0.727081 second(s), Total 47, Slave 42 queries .
