有一个新的BOXNUC7I3BNK NUC套件。
仅使用三星EVO 970 M.2 ssd。 BIOS将驱动器识别为M.2 ssd,但是 在启动面板中,不会将其识别为UEFI驱动器,仅作为Legacy驱动器。 我更新了最新的Bios,之后是针对Windows 10系统的英特尔支持文章000022600(5-11-18)。 第3项子项C说“在引导>引导配置菜单中,在UEFI引导窗格中,OS选择设置为 Windows 8.x / Windows 10“。我的Bios在UEFI引导窗格中没有OS选择选项。 请告诉我,我错过了什么。 提前致谢。 以上来自于谷歌翻译 以下为原文 Got a new BOXNUC7I3BNK NUC Kit. Only using a Samsung EVO 970 M.2 ssd. The bios recognized the drive as an M.2 ssd, but in the boot panel, does not recognize it as a UEFI drive, only as a Legacy drive. I updated to the most recent Bios, followed an Intel support article 000022600 (5-11-18) for Windows 10 system. Item 3 sub item C says to "On the Boot > Boot Configuration menu, in the UEFI boot pane, OS Selection is set to Windows 8.x/Windows 10". My Bios does not have an OS Selection option in the UEFI boot pane. Please tell me I am missing something. Thanks in advance. |
你好,sucko。
非常感谢您加入英特尔社区。我想澄清一下:您是否能够从启用了UEFI启动的驱动器启动?然后,您是否尝试过在UEFI启动中将SSD测试到另一个系统? 此外,您的M.2 SSD的部件号是多少?如果您可以共享英特尔®视频BIOS的Home和Boot页面的屏幕截图,我将非常感谢.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, sucko. Thank you very much for joining the Intel Community. I would like to clarify: Are you able to boot from the drive with UEFI boot enabled? Then, have you tried testing the SSD into a different system in UEFI Boot? Additionally, what is the part number of your M.2 SSD? I would highly appreciate if you can share a screenshot of the Home and Boot pages of the Intel® Visual BIOS. Antony S. |
你好,sucko。我想知道你是否还需要帮助。
如果是这样,请不要犹豫回复此主题.Antony S.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello, sucko. I would like to know if you still need assistance. If so, do not hesitate in replying to this thread. Antony S. Intel Customer Support Technician Under Contract to Intel Corporation |
519浏览 0评论
GMT+8, 2024-12-25 12:54 , Processed in 0.802324 second(s), Total 78, Slave 62 queries .
