当使用API中的SPI从属TX软件缓冲区时,如何在传输完成时得到中断?
即,当软件缓冲器已被转移到FIFO中时,但当软缓冲区中的传输的最后一个字节开始从TX引脚中出来时。 以上来自于百度翻译 以下为原文 When using the SPI slave tx software buffer in the API, how do I get an interrupt when a transfer is complete? I.e. not when the software buffer has been transferred into the FIFO, but when the last byte of the transfer placed in the soft buffer has started to come out of the TX pin. |
4个回答
修改SPIMA DMA示例也同样适用于我。
以上来自于百度翻译 以下为原文 Modifying the SPIS DMA example to do the same would also work for me. |
你好,
请浏览到SPI配置窗口的“高级”选项卡,并根据应用程序启用中断。 如果在传输完成时需要生成中断,则可以启用以下中断: 1。SPI中断 2。TXFIFO空中断 您还可以参考组件数据表,可以在HTTP://wwwyCysP.COM/FIL/185846/下载(第9页)获得。 谢谢, 山马西 以上来自于百度翻译 以下为原文 Hi, Please navigate to the "Advanced" tab of SPI configuration window and enable interrupts according to your application. If you require an interrupt to be generated when a transfer is complete, you could enable the following interrupts: 1. Interrupt on SPI done 2. Interrupt on Tx FIFO Empty You can also refer to component datasheet, available at http://www.cypress.com/file/185846/download (Page 9) Thanks, Shanmathi |
我在做同样的事情,但是SPI向量的中断在哪里,我期望看到一个SPILIT.C列表,但是没有? 以上来自于百度翻译 以下为原文 I am doing the same thing, but where does the interrupt for the SPI vector to, I expected to see an SPI_Int.c listing, but did not? |
没关系,找到它 以上来自于百度翻译 以下为原文 Never mind, found it |
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-24 01:33 , Processed in 1.046531 second(s), Total 84, Slave 68 queries .
