描述
The ti design is for automotive high side dimming rear light, which uses BCM to supply the rear light. In the TI design the high side driver TPS1H100-Q1 is used to output PWM supply with different duty cycle. Linear LED drivers TPS92630-Q1 and TPS92638-Q1 are used to drive the LEDs in constant (...) 主要特色 • High side dimming • Wide input voltage range: 12V Typical, 9-16V Continuous • Programable current limit high side driver • LED Open circuit, LED short circuit, LED driver output short to battery, device thermal shut down protection • Thermal Foldback function for LED driver • One fail all fail (...)
54908 浏览 1 评论
2655 浏览 2 评论
7016 浏览 0 评论
60843 浏览 0 评论
180892 浏览 1 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
84485浏览 4评论
2655浏览 2评论
119880浏览 1评论
3750浏览 1评论
5015浏览 1评论
GMT+8, 2024-11-13 15:59 , Processed in 1.316294 second(s), Total 74, Slave 52 queries .
