嗨,
我想将几台摄像机连接到英特尔航空板,但它只有一个USB-OTG连接。 我想知道是否有任何方法可以使这些连接可视化几个图像。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I would like to connect several cameras to the intel aero board but it only has one USB-OTG connection. I would like to know if there is any way to make these connections to visualize several images. Thank you. |
Hellojvela,感谢您对英特尔Aero计算板的兴趣。请您告诉我们您计划在主板上使用多少USB摄像头?
你想用什么相机? 请注意,您需要考虑的一些要求 - 在此处找到它们您可以使用有源USB适配器来增加可用的USB端口数量,但您需要确保它可以为所有摄像机提供足够的电量。 此外,您可以使用GStreamerto获取视频流。最好的问候,Eliza 以上来自于谷歌翻译 以下为原文 Hello jvela, Thank you for your interest in the Intel Aero Compute Board. Could you please let us know how many USB cameras are you planning to use with the board? What are the cameras that you want to use? Please note that are some requirements that you need to take into consideration - find them here You can use a powered USB adapter to increase the number of USB ports available, but you will need to make sure that it can provide enough power for all the cameras. Also, you can use GStreamer to get the video stream. Best regards, Eliza |
jerry1978 发表于 2018-11-6 09:45 嗨伊丽莎, 我曾想过要连接两三个摄像头,我没想过相机型号。 我会考虑使用USB适配器的选项。 非常感谢你。 以上来自于谷歌翻译 以下为原文 Hi Eliza, I had thought about connecting two or three cameras, I had not thought about the camera model. I will consider the option of using a USB adapter. Thank you very much. |
GMT+8, 2025-2-23 18:04 , Processed in 0.590629 second(s), Total 75, Slave 59 queries .
