有人可以帮我解释XC7K325T-2FFG900C FPGA的引脚名称。
实际上我想了解XC7K325T-2FFG900C FPGA中的GCIO引脚。 下面我附上了文件: - xc7k325tffg900pkg.txt 97 KB 以上来自于谷歌翻译 以下为原文 Can someone please help me with decoding pin names for XC7K325T-2FFG900C FPGA. Actually I wanted to know about the GCIO pins in XC7K325T-2FFG900C FPGA. Below I have attached the file :- |
4个回答
你好@ shubhamn
请查看以下用户指南中的“附录C”:https://www.xilinx.com/support/documentation/boards_and_kits/kc705/ug810_KC705_Eval_Bd.pdf 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @shubhamn Check "Appendix C" in the following user guide: https://www.xilinx.com/support/documentation/boards_and_kits/kc705/ug810_KC705_Eval_Bd.pdf Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@thakurr
我无法在上面的链接中找到Board part pin - > pcie_mgt_clkp。 你能告诉我我必须为pcie_mgt_clkp分配哪个软件包引脚吗? 以上来自于谷歌翻译 以下为原文 Hi @thakurr I am not able to find Board part pin -> pcie_mgt_clkp in above link. Can you please tell me which package pin I have to allocate for pcie_mgt_clkp? |
你好@ shubhamn
使用下面的包pin来分配pcie_mgt_clkp set_property PACKAGE_PIN U8 [get_ports PCIE_CLK_QO_P] 希望这可以帮助。 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @shubhamn Use below package pin to allocate pcie_mgt_clkp set_property PACKAGE_PIN U8 [get_ports PCIE_CLK_QO_P] Hope this helps. Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
HI @thakurr
我没有获得U8引脚选项,请参阅下面附图。 以上来自于谷歌翻译 以下为原文 HI @thakurr I am not getting U8 pin option please see the below attached image. |
2540 浏览 7 评论
2892 浏览 4 评论
2345 浏览 9 评论
3443 浏览 0 评论
2527 浏览 15 评论
2788浏览 1评论
683浏览 1评论
546浏览 1评论
838浏览 0评论
GMT+8, 2025-3-20 19:42 , Processed in 1.426022 second(s), Total 83, Slave 67 queries .
