最近,我有一个。
非常恼人的问题,即自动调光。 当屏幕背景较暗时,亮度会降低,而当亮度增加时,亮度会降低。 我尝试了很多解决方案,但所有这些都没用。 我尝试改变节省电池计划,但它没有工作。 然后我尝试从服务管理更改设置,但它也没有工作。 从更新系统到禁用intel iris图形修改中的自动设置。 我有一个解决方案 以上来自于谷歌翻译 以下为原文 recently, i have a. very annoying issue which is auto dimming. when the screen background is dark the brightness decrease and when its whit the brightness increase. i tried so many solution but all of them are useless. i tried changing saving battery plan but it didnt work. then i tried change the settings from service management but it didnt work either. all the way from updating the system until disabling auto setting in intel iris graphic modifications. i there is a solution for this |
您好MuhammadSaleh,感谢您加入英特尔社区。我发送了一条私信,以获取更多联系信息。
请检查您的收件箱.Regards,Fred D.Intel客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello MuhammadSaleh, Thank you for joining the Intel Communities. I sent to you a private message in order to get more contact information. Please check your inbox. Regards, Fred D. Intel Customer Support Technician Under Contract to Intel Corporation |
您好MuhammadSaleh,我发给您另一条私信,以防您没有收到上一封邮件。
请检查您的收件箱.Regards,Fred D.Intel客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello MuhammadSaleh, I sent to you another private message in case you did not receive previous one. Please check your inbox. Regards, Fred D. Intel Customer Support Technician Under Contract to Intel Corporation |
538浏览 0评论
GMT+8, 2025-1-14 14:19 , Processed in 0.548762 second(s), Total 44, Slave 39 queries .
