我使用HP6060B来表征锂离子电池的放电曲线。
当在恒定电流模式下将其设置为所需的负载电流时,我看到正确的电流测量值为0.5A,但是我没有在LCD上或通过GPIB接口获得正确的电压读数。 它仅显示0.01V而不是3.7V。 我做错了什么或误会了? 以上来自于谷歌翻译 以下为原文 I am using the HP6060B to characterize the discharge curve of a Li-ion battery. I see a correct current measurement of 0.5A when setting that as the desired load current in the constant-current mode, but I do not get the correct voltage reading on the LCD or through the GPIB interface. It is showing only 0.01V instead of 3.7V. What am I doing wrong or misunderstanding? |
嗨,设备背面有一个开关,可以将负载置于远程模式或本地模式进行电压测量。
如果它处于远程模式且未连接远程感测引线,则电压回读将关闭。 我认为这可能就是这种情况。 以上来自于谷歌翻译 以下为原文 Hi, There is a switch in the back of the unit that puts the load in either remote mode or local mode for the voltage measurement. If it is in remote mode and no remote sense leads are connected, then the voltage readback will be off. I think that this might be the case here. |
1291 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2065 浏览 5 评论
2952 浏览 3 评论
1117浏览 1评论
756浏览 0评论
929浏览 0评论
1292浏览 0评论
GMT+8, 2024-12-25 17:03 , Processed in 1.804475 second(s), Total 46, Slave 40 queries .
