有人测试了CYW92606WCDEVALL的校准测试集,如安立MT852B吗?我的评估板在低和高频率下EDR灵敏度和BER地板测试失败。我认为它可能是从与RF信号内联路由的滤波器的滚降,但是在零欧姆电阻的离散中切换没有更好的效果。我还注意到,与离散的阻抗匹配是可怕的,而它是合理的过滤器。
以上来自于百度翻译 以下为原文 Has anyone tested the CYW92706WCDEVAL with a calibrated test set such as the Anritsu MT8852B? My evaluation board is failing the EDR Sensitivity and BER Floor tests at the low and high frequencies. I thought it might be rolloff from the filter that is routed inline with the RF signal, but switching in the discretes with the zero ohm resistors had no better effect. I also noticed that the impedance match with the discretes is awful, whereas it is decent with the filter. |
尝试将射频连接器焊接到R12YC上,将MT852B直接连接到BT芯片上进行测试。这是芯片的RF性能负责。
当做 詹森 以上来自于百度翻译 以下为原文 Try to soldering the RF connector to R12_C which will connect the MT8852B to BT chip directly and test. This is accountable for chip's RF performance. Regards Jenson |
如果把PCB放在RF隔离箱中,灵敏度测试就会通过。 以上来自于百度翻译 以下为原文 If I place the PCB in an RF isolation box, the sensitivity tests pass. |
750个成员聚集在这个小组
加入小组2055 浏览 1 评论
1811 浏览 1 评论
3622 浏览 1 评论
1747 浏览 6 评论
1499 浏览 1 评论
484浏览 2评论
339浏览 2评论
401浏览 2评论
343浏览 2评论
836浏览 2评论
GMT+8, 2024-11-10 16:14 , Processed in 0.602750 second(s), Total 47, Slave 42 queries .
