嗨,
当我使用vivado v2016.4运行实现时,它永远停留在'运行opt_design'。 我觉得在我的设计中有一些与组合循环相关的东西,因为当我删除组合循环时,实现将顺利通过。 环路是振荡振荡器,如下所示。 (* ALLOW_COMBINATORIAL_LOOPS =“TRUE”,KEEP =“TRUE”*)wire [LENGTH:1] s; genvar i; 生成for(i = 1; i begin:osc_gen赋值s [i + 1] =〜s ; end endgenerate 和DONT_TOUCH约束包含在我的xdc中。 set_property DONT_TOUCH true [get_cells Inst_TDC_readout / osc_fast / s *] set_property DONT_TOUCH true [get_cells Inst_TDC_readout / osc_slow / s *] 任何通过组合循环传递opt_design的建议? 附上实施报告。 runme-log 959 KB 以上来自于谷歌翻译 以下为原文 Hi, When I run implementation with vivado v2016.4, it stuck at 'running opt_design' forever. I feel there is something related with combinational loop in my design, because when I remove the combinational loop, the implementation will pass smoothly. The loop is a ring oscillator, as shown below. (* ALLOW_COMBINATORIAL_LOOPS = "TRUE", KEEP = "TRUE" *) wire [LENGTH:1] s; genvar i; generate for(i=1;i assign s[i+1] = ~s; end endgenerate and DONT_TOUCH constraint is included in my xdc. set_property DONT_TOUCH true [get_cells Inst_TDC_readout/osc_fast/s*] set_property DONT_TOUCH true [get_cells Inst_TDC_readout/osc_slow/s*] Any advice to pass opt_design with combination loop ? The implementation report is attached. |
跑步完成了吗?
你也可以尝试不添加DONT_TOUCH吗? 问候 Sikta 以上来自于谷歌翻译 以下为原文 Did the run ever complete? Also Can you try without adding the DONT_TOUCH? Regards Sikta |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2517 浏览 15 评论
2620浏览 1评论
670浏览 1评论
534浏览 1评论
821浏览 0评论
GMT+8, 2025-3-6 02:41 , Processed in 1.295175 second(s), Total 44, Slave 39 queries .
