我有一个配备i7 7700hq和GTX 1050 4GB的HP Pavilion Power笔记本电脑,带有英特尔XTU,我总是得到限流限制,将CPU缓存频率降低到0.80 GHZ,这是否导致游戏中的FPS下降,因为我遇到了大量的FPS下降
我玩的每一款游戏,都是精准的,我在微软火车模拟器等极低要求的游戏中遇到FPS掉落。 所有驱动程序都更新为letest版本,Windows也是最新版本。 以上来自于谷歌翻译 以下为原文 I have a HP Pavilion Power Notebook with i7 7700hq and GTX 1050 4GB,with intel XTU I always get Current limit throttling as yes which reduces CPU Cache frequency to 0.80 GHZ,Does this cause FPS drops in Games cause I am experiencing heavy FPS drops in every game I play,to be precised I am experiencing the FPS drops on very low demanding game such as Microsoft Train Simulator. All drivers are updated to the letest version and Windows is also upto date. |
6个回答
你使用惠普的图形驱动程序了吗?
如果没有,你应该。 文件 以上来自于谷歌翻译 以下为原文 Did you use the graphics driver from HP? If not, you should. Doc |
我使用HP恢复将笔记本恢复到出厂设置,我想它会将所有驱动程序恢复为默认值,即HP
以上来自于谷歌翻译 以下为原文 I used HP recovery to restore my Notebook to factory settings,I guess it restores all the drivers to default i.e. from HP |
是的,恢复图像中的任何内容都是恢复的内容。 完成后,您应该确保已从HP站点更新了驱动程序。 文件 以上来自于谷歌翻译 以下为原文 Yes, whatever is in the recovery image is what is restored. Once done, You should make certain that you have updated the drivers from the HP site. Doc |
是的我已经更新了驱动程序,但是你能否告诉我什么是当前的限制节流并且它会导致这样的FPS下降?
以上来自于谷歌翻译 以下为原文 Yes I have updated the drivers,but can you please tell me what is current limit throttling and can it cause such FPS drops ?? |
这是播放GTA 5时我的笔记本的HWinfo日志
log.CSV - Google云端硬盘 以上来自于谷歌翻译 以下为原文 This is HWinfo Log of my Notebook while playing GTA 5 log.CSV - Google Drive |
您好Akashk17感谢您的信息。请允许我与您分享您的系统上的FPS,如果由离散GPU控制他们不应该有任何下降。 如果发生这种情况,我建议使用原始设备制造商(OEM)验证此行为。 此致Leonardo C.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello Akashk17 Thank you for the information. Allow me to share with you that the FPS on your system if the at control by the discrete GPU they should not have any drop. In case this is happening I would recommend verifying this behavior with the Original Equipment Manufacturer (OEM). Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
GMT+8, 2025-4-22 12:25 , Processed in 2.645872 second(s), Total 85, Slave 69 queries .
