构建intel s2600gz服务器
操作系统:esxi6.5 CPU:2680v2 * 2 记忆:三星12800 8g * 2 BMC Rev:1.28.11044 ME Rev:02.01.07.328安装了Bios:SE5C600.86B.02.06.E006 在bmc中错误传感器读数错误 这个传感器的目的是什么?以及如何解决这个错误的传感器读数 以上来自于谷歌翻译 以下为原文 building an intel s2600gz server os:esxi6.5 cpu:2680v2*2 memory:Samsung 12800 8g*2 BMC Rev:1.28.11044 ME Rev:02.01.07.328 installed Bios:SE5C600.86B.02.06.E006 fouding wrong sensor reading in bmc What is the purpose of this sensor?And How to solve this wrong sensor reading
8个回答
你好Brabbit1996
您可以与我们共享服务器主板上的EFI Syinfo日志,以便更好地为您提供帮助吗? 问候, Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello Brabbit1996 Can you share the EFI Syinfo logs from the server board with us in order to better assist you? Regards, Charlie_Intel |
HelloBrabbit1996
我当然知道 但是如何在英语和英特尔服务器中导出这个日志,初学者,是否有任何教程? 以上来自于谷歌翻译 以下为原文 sure i do but how to export this log,beginner in both English and intel server,is there any tutorial? |
HelloBrabbit1996,当然,请按照链接中的步骤操作:https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html?_ga = 2.39412259。 1281798578.1537168176-93677472.1524465305& erpm_id = 6305461告诉我们您是否还有其他问题,或者您是否需要逐步解释。请注意,Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello Brabbit1996, Sure, please follow the steps in the link: https://www.intel.com/content/www/us/en/support/articles/000023940/server-products/server-boards.html?_ga=2.39412259.1281798578.1537168176-93677472.1524465305&erpm_id=6305461 Let us know if you have further questions or if you need a steply explanation. Regards, Charlie_Intel |
jerry1978 发表于 2018-11-2 19:05 HelloBrabbit1996,如果您能够按照链接中的步骤,请告诉我们。另外,我们收到了SEL日志,我们想知道您在系统中使用了哪种内存?问候,Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello Brabbit1996, Please let us know if you were able to follow the steps in the link. Also, we have received the SEL logs and we are wondering what kind of memory are you using in the system? Regards, Charlie_Intel |
cjynet 发表于 2018-11-2 19:18 内存型号:M393B1K70DH0-CK0 以上来自于谷歌翻译 以下为原文 Memory Model: M393B1K70DH0-CK0 |
cjynet 发表于 2018-11-2 19:18 你好Brabbit1996, 所有已安装的内存都是同一型号?这通常与不兼容的内存电压有关,您是否可以通过EFI测试更新固件并使用最小系统要求,1个内存和1个处理器进行测试? 在那之后,如果有相同的问题清除SEL并清除c / mos并让我们知道它是怎么回事。 问候, Charlie_Intel 以上来自于谷歌翻译 以下为原文 Hello Brabbit1996, All the installed memory is the same kind of model? This is normally related to a non-compatible memory voltage, can you test updating the firmware by EFI and using the minimal system requirements, 1 memory and 1 processor for testing purposes? After that, if having the same issue clear the SEL and clear the c/mos and let us know how it goes. Regards, Charlie_Intel |
449浏览 0评论
GMT+8, 2024-11-13 09:53 , Processed in 0.592502 second(s), Total 58, Slave 53 queries .
