您好,我正在尝试在英特尔Edison Aruino分线板上安装英特尔Edison交叉编译器工具链。
我从下载英特尔®Edison交叉编译器工具链下载了32位文件并执行Bash脚本。 然后我收到以下错误: -------------------------------------------------- -------------------------------------------------- ---------- 输入SDK的目标目录(默认值:/opt/poky-edison/1.7.3): 您即将将SDK安装到“/opt/poky-edison/1.7.3”。 继续[Y / N]?ÿ 提取SDK ... DONE 设置它...找不到:无法识别:-printf BusyBox v1.22.1(2016-06-06 14:50:27 PDT)多调用二进制。 用法:找[-HL] [路径] ... [选项] [动作] 无法设置SDK。 重定位脚本失败。 中止! -------------------------------------------------- -------------------------------------------------- ---------- 有谁知道如何解决这个问题? 提前致谢 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to install the Intel Edison Cross Compiler Toolchain on the Intel Edison Aruino Breakout Board. I downloaded the 32-Bit file from Download Intel® Edison Cross Compiler Toolchain and execute the Bash Script. Then i get the following error: -------------------------------------------------------------------------------------------------------------- Enter target directory for SDK (default: /opt/poky-edison/1.7.3): You are about to install the SDK to "/opt/poky-edison/1.7.3". Proceed[Y/n]?Y Extracting SDK... done Setting it up...find: unrecognized: -printf BusyBox v1.22.1 (2016-06-06 14:50:27 PDT) multi-call binary. Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS] SDK could not be set up. Relocate script failed. Abort! -------------------------------------------------------------------------------------------------------------- Does anyone know how to solve this issue? thanks in advance |
4个回答
HelloParaphase,感谢您对英特尔Edison Arduino分组讨论区感兴趣。我们已经确认了您的请求,我们正在努力。我们会尽快与您联系。谢谢,Eliza
以上来自于谷歌翻译 以下为原文 Hello Paraphase, Thank you for your interest in the Intel Edison Arduino Breakout Board. We have acknowledged your request and we are currently working on it. We will reach you back as soon as possible. Thank you, Eliza |
jerry1978 发表于 2018-11-2 16:58 亲爱的伊丽莎, 谢谢您的时间。 我希望你们找到解决方案 问候 倒相 以上来自于谷歌翻译 以下为原文 Dear Eliza, Thanks for Taking your TIme on it. I'll hope you guys find a solution Greetings Paraphase |
您好Paraphase,感谢您的耐心等待。我已经在Linux 64位计算机上进行了测试,我设法安装了Edison Cross编译器工具链而没有任何错误。这是我使用过的命令:wget http://downloadmirror.intel .com / 25028 / eng / edison-sdk-linux64-ww25.5-15.zipunzip edison-sdk-linux64-ww25.5-15.zip ./poky-edison-glibc-x86_64-edison-image-core2-32 -toolchain-1.7.2.sh如果这对您有用,请告诉我!最好的问候,Eliza 以上来自于谷歌翻译 以下为原文 Hello Paraphase, Thank you for your patience. I have tested on a Linux 64-bit machine and I managed to install the Edison Cross Compiler Toolchain without any error. Here are the commands that I have used: wget http://downloadmirror.intel.com/25028/eng/edison-sdk-linux64-ww25.5-15.zip unzip edison-sdk-linux64-ww25.5-15.zip ./poky-edison-glibc-x86_64-edison-image-core2-32-toolchain-1.7.2.sh Please let me know if this works with you as well! Best regards, Eliza |
jerry1978 发表于 2018-11-2 17:19 HelloParaphase,如果上述解决方案有效,请告诉我们。期待您的回复!最好的问候,Eliza 以上来自于谷歌翻译 以下为原文 Hello Paraphase, Could you please let us know if the solution above mentioned worked? Looking forward to your reply! Best regards, Eliza |
536浏览 0评论
GMT+8, 2025-1-9 15:36 , Processed in 0.820046 second(s), Total 83, Slave 67 queries .
