你好。
我有一台联想SR650,带有Intel X722 10 Gb接口。 用作备份服务器。 我在2012 R2版本中使用windows功能配置了teamin。 我还配置了组合接口(使用VLAN),因为我需要此服务器在不同的网段中具有直接连接。 问题是,当客户端将数据发送到备份服务器时,我的性能会很差。 我有20 Gb基础设施,客户端发送的数据不超过800 Mb / s。 我已经停用TCP校验和卸载并获得了更好的性能。 但这并没有多大帮助。 停用其他功能没有帮助。 有谁遇到过这样的问题? 是否有可用于在Windows 2012 R2上创建团队的英特尔软件? 最好的祝福! 以上来自于谷歌翻译 以下为原文 Hi. I have a Lenovo SR650, with Intel X722 10 Gb interfaces. Used as backup server. I have configured teamin using the windows feature in 2012 R2 version. I have also configured teaming interfaces (with VLAN), because i need this server to have direct connections in different network segments. The thing is that i get poor performance when the client send the data to the backup server. I have 20 Gb infrastructure and the clients send data with no more then 800 Mb/s. I have deactivated TCP checksum offload and got a little better performance. But does not help that much. Deactivating other features did not help. Has anyone experienced such issues? Is there a software form Intel that could be used in order to create the teaming on windows 2012 R2? Best regards! |
3个回答
您好Alexia-net,感谢您在英特尔有线以太网社区发帖。
请从系统支持实用程序发布日志,以便更好地了解服务器和客户端系统上的驱动程序和组合/ VLAN配置。 FAQ提供有关此实用程序的其他信息。 从上面的链接下载并运行.exe检查“所有内容”然后单击“扫描”扫描完成后单击“下一步”保存日志并将其附加到postAdvanced网络服务可用于从设备属性创建团队/ VLAN 装置经理。 什么是客户端和服务器连接?如果您有任何疑问,请不要犹豫与我们联系。最好的问候,丹尼尔D 以上来自于谷歌翻译 以下为原文 Hello Alexia-net, Thank you for posting in Intel Wired Ethernet Communities. Please post the logs from the System Support Utility to give us a better idea of the drivers and teaming/VLAN configurations on your server and client systems. The FAQs have additional information about this utility.
If you have any questions please do not hesitate to contact us. Best regards, Daniel D |
jerry1978 发表于 2018-11-2 11:07 您好Alexia-net,如果您仍然需要有关此问题的帮助,请告诉我们。 如果安装高级网络服务帮助您解决问题,或者如果您在提供SSU信息时遇到困难,请通知我们。最好的问候,Daniel D 以上来自于谷歌翻译 以下为原文 Hello Alexia-net, Please let us know if you still need assistance with this issue. If installing Advanced network services has helped you with the issue, or If you are having difficulty providing the SSU information please inform us. Best regards, Daniel D |
cd340823 发表于 2018-11-2 11:24 您好Alexia-net,如果您对此问题仍有疑问,请告诉我们。最好的问候,Daniel DIntel客户支持 以上来自于谷歌翻译 以下为原文 Hello Alexia-net, Please let us know if you still have any questions regarding this issue. Best regards, Daniel D Intel Customer Support |
573浏览 0评论
GMT+8, 2025-2-12 16:03 , Processed in 0.844157 second(s), Total 79, Slave 63 queries .
