你好,
我在“卸载程序”中找不到英特尔图形设置软件。 因此,我该怎么做才能删除该软件,以免它出现在我的任务栏中? 提前致谢。 以上来自于谷歌翻译 以下为原文 Hello there, I can't find the Intel Graphics Settings software inside "Uninstall a program". As such, what do I do remove that software so it doesn't appear somewhere in my taskbar? Thanks in advance. |
5个回答
您好DrWongKC,感谢您加入此英特尔社区。根据您的计算机所具有的独立显卡,您可以强制它打开某些应用程序和游戏,以提高系统的整体性能。具体说,您的系统型号是什么?
游戏时是否遇到任何问题?另外,请附上任务栏显示的软件图片。请运行英特尔®系统支持实用程序并将报告附加到此主题.1。下载英特尔®系统支持实用程序并保存应用程序 到您的系统.https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product = 916002。打开应用程序,然后单击扫描以查看系统和设备信息。 英特尔®系统支持实用程序默认为扫描后输出屏幕上的摘要视图。 单击其中显示摘要的菜单以更改为详细视图.3。要保存扫描,请单击“下一步”,然后单击“保存”。 您可以将文件保存到计算机上任何可访问的位置.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello DrWongKC, Thank you for joining this Intel Community. Depending on the discrete graphics your computer has, you can force it to open certain applications and games to improve the overall performance of your system. Having said that, what is your system model? Do you experience any issues while gaming? Also, please attach a picture of the software the taskbar displays. Please run the Intel® System Support Utility and attach the report to this thread. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. Wanner G. |
您好,我此时没有安装外置GPU。
我想知道当我购买外置GPU并且不再使用英特尔集成GPU时,如何从计算机中删除此高清图形设置。 我忘了提到我正在使用定制PC,运行带有华硕H370-F主板和PCIe SSD的i3-8100.It是8GB的RAM。 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I do not have an external GPU installed at this moment in time. Just I'd like to know how I can remove this HD graphics settings from the computer for the future when I buy an external GPU and no longer use Intel's integrated GPU. I forgot to mention that I'm using a custom PC, running i3-8100 with a Asus H370-F motherboard and PCIe SSD.It's 8GB of RAM. Thank you. |
cd340823 发表于 2018-11-2 12:26 你好DrWongKC, 感谢您的答复。 为此,您可以执行以下步骤: 1.在Windows *设备管理器中禁用集成显卡。 右键单击列出的显示,然后选择“禁用”。 2.通过“设备管理器方法”卸载英特尔图形驱动程序。 3.通过“添加/删除程序”方法卸载英特尔图形驱动程序。 https://www.intel.com/content/www/us/en/support/articles/000005598/graphics-drivers.html 我希望您发现此信息有用。 万纳G. 以上来自于谷歌翻译 以下为原文 Hello DrWongKC, Thank you for your response. To achieve this, you can perform these steps: 1. Disable the integrated graphics in Windows* Device Manager. Right click on the listed display and select Disable. 2. Uninstall the Intel Graphics Driver via the Device Manager Method. 3. Uninstalling the Intel Graphics Driver via the Add/Remove Programs Method. https://www.intel.com/content/www/us/en/support/articles/000005598/graphics-drivers.html I hope you find this information helpful. Wanner G. |
您好,我无法在“添加/删除程序”部分找到它。 请问,如果我使用设备管理器方法卸载它,是否意味着隐藏在任务栏选项卡中的英特尔图形设置也将消失? 如果是或否,那就是我正在寻找的答案。 问候, 启创 以上来自于谷歌翻译 以下为原文 Hello, I'm unable to find it in my Add/Remove Programs section. May I ask, if I were to uninstall it using the Device Manager method, does that mean that the Intel Graphics Settings hidden in the Taskbar tab will be gone too? If yes or no, that'd be the answer I'm looking for. Regards, Kai Chong |
60user103 发表于 2018-11-2 12:47 HelloDrWongKC,通过设备管理器方法卸载英特尔图形驱动程序意味着您将使用Microsoft基本显示适配器。 换句话说,英特尔图形托盘图标不应该可用。值得注意的是,您也可以右键单击该图标并选择退出托盘.Wanner G.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello DrWongKC, Uninstalling the Intel Graphics Driver via the Device Manager Method means that you will be using the Microsoft Basic Display Adapter. In other words, the Intel Graphics Tray Icon should not be available. It is worth noting that you can also right-click the icon and select Exit Tray. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
GMT+8, 2025-4-19 20:47 , Processed in 1.813188 second(s), Total 83, Slave 67 queries .
