你好
我使用了VIVADO 2016.1,但我遇到了一个问题。 我找到一些关键的真值表& nbsp; 在实现后,LUT被更改,因此导致我不希望的逻辑错误。 我怎样才能避免这种情况发生? 有什么办法可以让我在实现过程中不改变真值表吗? 以上来自于谷歌翻译 以下为原文 Hello I used VIVADO 2016.1 ,but I met a problem. I find some critical truth tables of the LUTs been changed after Implemetation , so causing a logic error that I don't wished. How can I avoid this happening? Is there some way that I can make the truth table not being changed during Implemetation ? |
4个回答
你好@ dreamertom
检查您是否正在运行ARhttps://www.xilinx.com/support/answers/67439.html中描述的问题 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @dreamertom Check if you are running in to issue described in AR https://www.xilinx.com/support/answers/67439.html Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
你好@ dreamertom
检查您是否正在运行ARhttps://www.xilinx.com/support/answers/67439.html中描述的问题 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @dreamertom Check if you are running in to issue described in AR https://www.xilinx.com/support/answers/67439.html Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨@ dreamertom,
可以请检查以下答案记录是否有帮助: https://www.xilinx.com/support/answers/67439.html 如果这没有帮助,那么请您详细说明您面临的问题。 问候, Sravanthi B 以上来自于谷歌翻译 以下为原文 Hi @dreamertom, Can you please check if the below answer record helps: https://www.xilinx.com/support/answers/67439.html If this does not help then can you please elaborate more on the issue your facing. Regards, Sravanthi B |
谢谢。
您提供的AR与我的情况非常相似。 但是当我在“实施设置”中禁用了选项opt_design时,真值表仍然被更改。 为什么会这样? 我会首先尝试你的解决方案,看看它是否有效。 以上来自于谷歌翻译 以下为原文 Thanks. The AR you provided is much similar to my situation. But when I disabled the option opt_design in the Implementation Settings, truth tables are still been changed. Why this happened ? I will try your solution first and look if it works . |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 17:48 , Processed in 1.273175 second(s), Total 82, Slave 66 queries .
