我刚刚在我的电脑上运行了SPINFamily eval软件,可以用它来控制我的电机。但是,我刚进入寄存器映射将步进模式从1/128更改为完整步骤。事实证明,无论我写什么价值,当我读回它时,它仍然设置为1/128。我已经更改了寄存器映射中的其他值,例如OCD和失速阈值,并且可以毫无问题地设置这些值。有没有人见过这个?
我在一两个星期前下载了这个软件,但是无法让IBUUI工作(它只是一直崩溃)。但是这个更新程序应该与评估软件如何设置注册有关,对吧? #l6470 #eval #step-mode 以上来自于谷歌翻译 以下为原文 I just got the SPINFamily eval software running on my PC, and can control my motor with it. However, I just went into the Register Map to change the step mode from 1/128 to full step. It turns out that no matter what value I write, when I read it back it is still set to 1/128. I have changed other values in the Register Map, such as the OCD and stall thresholds, and those values can be set without problems. Has anyone else seen this? I downloaded the software just a week or two ago, but haven't been able to get the IBUUI to work (it just crashes all of the time). But this updater should have anything to do with how the evaluation software sets registers, right? #l6470 #eval #step-mode |
这是我的IBUUI更新程序所做的...
(无法弄清楚如何使用Image Uploader上传图像,所以......) DFUSeConsole.exe - 应用程序错误 应用程序无法正确启动(0xc0150002)。单击“确定”关闭应用程序。 这种情况发生在弹出窗口“更新固件......不要重新插入或重置电路板!!!”之后。 当我关闭消息时,它会说''更新无法完成。您当前的固件版本不支持DFU。请通过JTAG程序员更新您的电路板。'' 以上来自于谷歌翻译 以下为原文 Here is what my IBUUI updater does... (couldn't figure out how to upload an image with the Image Uploader, so...) DFUSeConsole.exe - Application Error The application was unable to start correctly (0xc0150002). Click OK to close the application. This happens right after the popup that says ''Updating firmware... DO NOT UNPLUG OR RESET THE BOARD!!!''. When I close the message, it then says ''The update cannot be completed. Your current firmware version do not support DFU. Please, update your board through a JTAG programmer.'' |
2906 浏览 1 评论
3290 浏览 1 评论
1870 浏览 1 评论
3724 浏览 6 评论
6134 浏览 21 评论
GMT+8, 2025-3-9 09:11 , Processed in 0.517018 second(s), Total 42, Slave 37 queries .
