我在旧电脑上成功使用了皮卡多年。现在我有了一台新的PC,我安装了MPLAB-X 4.15并连接了PICtiT3。通过MPLAB对PICTIT3进行检测,下载新的固件。在此之后,PC将无法检测到PICTIT3和Windows设备管理器说“这个设备不能启动”。设备USB VIDY04D8&PIDY900ABUR090910366有一个问题开始。驱动程序名称:INPUT.INFACE GUID:{75A1703-7D3-11D0B6FE-0A0C90F57 DA}服务:HidU***Lower过滤器:上过滤器:问题:0xAcActudio状态:0xC000 00?1我怎么解决这个问题?我试着用按钮按下USB插头,但我遇到了同样的问题。
以上来自于百度翻译 以下为原文 I used pickit successfully on my old PC for years. Now I have got a new PC I installed MPLAB-X 4.15 and connected the pickit3. The pickit3 was detected and new firmware was downloaded for it by MPLAB. After this the PC will not detect the pickit3 and windows device manger says "This device cannot start". Device USBVID_04D8&PID_900ABUR090910376 had a problem starting. How can I fix this? I have tried plugging in the USB with button pressed down but I have the same problem. |
5个回答
尝试使用MPLAB IPE.在插入USB时有按钮的插入…改变MPLAB模式和另一种模式…
以上来自于百度翻译 以下为原文 Try using MPLAB IPE. there was something with pushing the button while plugging in USB... changing MPLAB mode and another mode... |
我看到您已经打开了设备管理器,并且列出了PICTIT3,因此它显示了驱动程序或设备的状态。Win8. x和Win10之间发生了变化。在我的WI10机器上,在人机界面设备上,我的输入是USB输入设备。在Win8上,它作为微芯片WinUSB设备在微芯片工具之下。您可能需要卸载驱动程序,然后插入PICTIT3,并允许它枚举和重新安装驱动程序。另一个要尝试的是使用MPLAB 8.92来查看它是否工作。
以上来自于百度翻译 以下为原文 I see you have opened Device Manager and the PICkit3 is listed, so it shows the driver or the status of the device. There has been a change between Win8.x and Win10. That input.inf driver is what I have on my Win10 machine, under Human Interface Devices, as USB Input Device. On Win8, it is under Microchip Tools as Microchip WinUSB Device. You may need to uninstall the driver and then plug the PICkit3 in and allow it to enumerate and reinstall the driver. Another thing to try is using MPLAB 8.92 to see if it works. |
HI,当没有其他工作时同意(以前的MPLAX版本),它通常是迫使皮卡3重新加载固件的最有效方式。
以上来自于百度翻译 以下为原文 Hi, Agreed when nothing else works (previous MPLAB X version) it is generally the most efficient way to force PICkit 3 to reload firmware Regards |
如果您在PICTIT3上按住按钮,同时插入它,它将在它的引导加载程序中启动。
以上来自于百度翻译 以下为原文 If you hold the Button on the PICKit3 while plugging it in, it will start in its bootloader. |
尝试了各种方法,如按住按钮和卸载驱动程序,无法用MPLAB-X在Windows 10或Windows 7上工作。在Mac上尝试它,它运行良好,所以问题解决了。
以上来自于百度翻译 以下为原文 Tried all sorts of things such as holding down the button and uninstalling the driver and couldn't get it working on Windows 10 or Windows 7 with MPLAB-X. Tried it on a MAC and it works fine, so problem sorta solved. |
5142 浏览 9 评论
1990 浏览 8 评论
1918 浏览 10 评论
3159 浏览 3 评论
2215 浏览 5 评论
710浏览 1评论
598浏览 1评论
481浏览 1评论
610浏览 0评论
508浏览 0评论
GMT+8, 2024-11-10 15:59 , Processed in 0.940168 second(s), Total 53, Slave 48 queries .
